250-500cc Anyone Use This Rear Rotor?
Discussion in '2 Stroke' started by be4life182, May 17, 2019.
  1. be4life182 Husqvarna
    09 WR250
    18 Yamaha WR450
  2. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    The correct bolts are supposed to be stepped from what I can remember. I have used those rotors and bought the correct bolts direct from my local Husky dealer who had them on the shelf.
  3. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Just found this pic of one of my old sets of wheels and the bolts used on this one came from a TM, They were used somewhere on a tm to hold the plastics on but were a perfect fit for the rear rotor if that helps in finding something.
    Dirtdame likes this.
  4. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I bought one of those rotors (which I have not installed). As near as I can tell, the problem stems from the fact that the stock rotor is a floating design, while the aftermarket one is not. That's why the different hardware situation happens.
  5. Crocus Paper Husqvarna
    UK
    WR250
    Scorpa 300 Aprilia Dorsoduro 750
    Yes, I have one of those fitted on the rear. I couldn't find any bolts, so I bought some that were close (honda I think) and got a machinist to 'make em fit'.
  6. be4life182 Husqvarna
    09 WR250
    18 Yamaha WR450
    Anything helps. I know the type of bolt it would take roughly I just got to find one that works. Anyone use a motosportz rear non-floating rotor? i think they may sell some that work.
  7. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    ktm / husky 65 rear bolts will fit from looking at a wheel in my garage
  8. be4life182 Husqvarna
    09 WR250
    18 Yamaha WR450
    Thanks for checking Johnny, i'll try them and report back in case someone pulls this up in the future.
  9. be4life182 Husqvarna
    09 WR250
    18 Yamaha WR450
  10. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Kwaka ones are slightly too small on the step diameter. Can't get genuine Husky ones(WR125/TE310 etc)?
    Metal Gear in Australia do them but about $30 from memory.
  11. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    I went for a similar route with my WR300 2010, had a lot of play with the OEM floating assembly and wanted to get rid of the noise in the rear, my friends were constantly saying that something is loose :D
    I do also ride often in muddy conditions so I opted for a non-drilled rotor, I got an NG 263SP:
    https://ngbrakes.com/en/catalogo/husqvarna-cr-rear-263sp/
    As that rotor is not using the OEM floating 'washers' I needed to buy some special bolts, I got some OEM Husky parts from a TE 449/551 11-14 M6 X 1.00 X 11 Ref: 800055878 for 1,88 € each
    Cheers !
  12. be4life182 Husqvarna
    09 WR250
    18 Yamaha WR450
    Thanks for this input as I was about to try the kawi ones.
    Thanks for providing the PN. I did not know the TE had a non floating rotor with an OEM bolt solution. Cheers
    Borntoride71 likes this.
