TE/TC AOMC Mikuni Jet kit for 17 TE/TC/TX model 250/300
Discussion in '2st' started by robertaccio, Apr 19, 2017.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    Another option to take away some of the guess work. (remember to check the float level before chasing your tails, JD Jetting has acknowledged this issue as well)
    http://www.ktm-parts.com/AMP2600.html
  2. KennyMc Husqvarna
    Placentia, California
    '16 FE 501-S
    '17 KTM 300XC-W
    Is that the S-1 needle jet?
  3. robertaccio Husqvarna
    San Diego, Ca
    ask aomc I have no idea. I just want a new brass collection for the new machine mikuni, I have oem kit, jd jetting and now aomc , so far oem is fine and seems to match the book chart very well once I lowered the daggone float height that would spill fuel at even the slightest side lean angle.
  4. KennyMc Husqvarna
    '16 FE 501-S
    '17 KTM 300XC-W
    Well, there has been a lot of discussion about replacing the needle jet. The stock one is the R-8 and I believe the next rich one is the S-1. That has been the discussion that the lean needle jet has ben causing one to have to have a big pilot jet. Changing the needle jet is a bit more tricky.
    It goes:
    R-8 = 2.79mm
    S-1 = 2.805mm
    S-4 = 2.820mm
    Diameter of the hole.
    robertaccio likes this.
  5. 95jersey Husqvarna
    TXC310R
    2014 Gas Gas 300 XC
    I just installed a JD kit and it vastly improved the jetting. Not 100% perfect (yet), but way better. No more bottom end bog. I can't believe they went down to a 30 pilot from a stock 37.5. That is a huge jump
  6. ripnriding Husqvarna
    Kingston, Ontario Canada
    2017 TX 300 and 2010 CR 144
    2007 husqvarna TE 450(sold)
    I had a full season on the TX and made some subtle changes along the way. Final jetting as follows with significant improvements when I "opened" up air box that included holes on top of air side and open hole on right side:
    Needle: 6bfy44-74 top clip
    430 main(stock)
    35 idle(went from 37.5 stock) definitely improved bottom
    80 starter jet(stock)
    Kingston ontario 0-3000 ft riding ranged across Ontario but pretty flat..
    Now why did I order the JD kit....good question....will certainly update when I install and compare but I now have my GOTO summer settings with the above in case the JD won't make gains. BTW plug was a nice marshmellow brown but still a taaad on the rich side.
