Are G650GS wheels bolt on compatible?
Discussion in 'TR650' started by Ogre_fl, Jul 16, 2013.
  1. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Does anyone know?
    They sure look identical to the Strada's.
  2. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    Someone had mentioned that the Strada wheels were stamped "BMW" right on them.
  3. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    Spacers may be different ...but they do have the stamp
  4. Motosportz CH Sponsor
    I think they are identical.
  5. Toyboy Husqvarna
    Middletown, PA
    2011 TXC250/2012 TXC310, 2013 TR650
    BMW Hp2E/Yamaha Super T/BMW R1200RTP
    I have both, they are the same.
    Ogre_fl likes this.
  6. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Is the Strada a 3" wide or 3.5" wide rear rim?
    The parts manual, service manual and owners manual says 3"
    But the online specs says its 3.5", which matches the G650GS
  7. Ignaciob Husqvarna
    Tri-Cities, WA
    TR650 Strada --> Terra (aka Noxeema)
    05 Yamaha FJR (x2), 75 Honda CB400F
    It's a 4 1/8" rim on the outside edges as I just measured with a makeshift caliper/C-clamp....I'm pretty sure it's a 3.5" rim. I also measured my used Dakar rim that has 3.00" stamped on it...and it's 3 5/8"....so I'm even more sure the stock Strada rear rim is 3.5"...short of taking off the tire off the rim and measuring.
  8. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Cool, thanks for talking the time to measure.
  9. Ignaciob Husqvarna
    Tri-Cities, WA
    Double confirmed. Snapped a picture of the wheel with it off. I do believe it says, "3.5x17".
  10. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Yup...Identical.
    Thanks again
    Motosportz likes this.
  11. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    OK, now for the front wheel.
    Can any of you Strada guys confirm that your wheels have 7722554 stamped on the hub on the opposite side from the disc?
  12. hasenpfeffer Husqvarna
    CO
  13. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Thank you!!!
  14. Ignaciob Husqvarna
    Tri-Cities, WA
    Assuming you got confirmation the part number is the right part of the add and the model is not....that's a GOOD deal....especially if it has a rotor and ABS ring on it.
  15. Motosportz CH Sponsor
    thats a great deal. thanks for sharing.
