Argh Rekluse!
sidunvicious
Finally worked up to installing Rekluse Z start pro. Smooth going until i was finishing the pressure plate. 4 of the Torx screw sheared off 2mm below the head! Torque wrench set to 25 ft-lbs as directed.
Call Rekluse on Monday to see if i can get another lower assembly. Dang, so close to being done!http://www.cafehusky.com/forums/images/smilies/banghead.gif
Oh noes! Yeah, those are tiny screws. Those get about 4 or 5 foot pounds. 25 ft pounds is for the big nut that goes on the shock absorber shaft and stuff like that.
You may be able to remove them with a small screw extractor bit. Just be careful to keep the drill bit centered so you don't ruin the clutch threads.
Are you a butcher by trade (sorry).. Best tool to use to remove what's left would be a "Micro-DRILL-OUT®" in "M4 Size" (not easy to find in micro sizes)..
To help a Husky brother (or sister out) in the time of need.. PM me your address and I'll send you one for FREE (but please be careful when using or find
someone with a more delicate touch to help you).. You'll have to order new bolts from Rekluse though.. Hope that helps.. Now try and enjoy the rest of
your weekend.. Cheers.. :cheers:
I know it sucks, but everybody makes mistakes. You can put enough torque on a screw that size with a hand screw driver type Torx bit driver. Even twist them off if you're ham fisted enough.
Live, learn, move on.
