Arrow exhaust
Discussion in '610/630' started by mandolin, Apr 7, 2013.
  1. mandolin Husqvarna
    Hungary
    SM 610 ie '09
    DSCF3056.JPG http://www.supermotojunkie.com/showthread.php?62106-All-exhaust-for-Husqvarna-SM-TM-610
    Here is a list of exhaust that fit te/sm 610
    What whil happen with te senzor in the photo? DSCF3056.JPG I found one,an Arrow.I want to put it on. View attachment 24917
  2. 1lunger Husqvarna
    Bloomfield CT
    That looks like a stock can that someone riveted an Arrow logo to.
  3. mandolin Husqvarna
    Hungary
    SM 610 ie '09
    no,it has te logo on it to: 476e3c67a57a2e0681a084ca580bab71-80672-700_700.jpg
  4. 1lunger Husqvarna
    Bloomfield CT
    To answer the question nothing, but if you still have the o2 sensor in the bikes not powered up aka running race map. This means the bikes running lean and only giving about 70% of the possible 100% power
    mandolin likes this.
  5. mandolin Husqvarna
    Hungary
    SM 610 ie '09
    it has enough power as it is. So i only change the cans and that;s it? :)
  6. 1lunger Husqvarna
    Bloomfield CT
    Yes, but its not all about power. The bike will run lean and that will make it run hotter. It's only about $45 for the kit and it takes 5min to do. You will get rid of the canister on the other side too. You can also get the part for $1.50 and leave the o2 in place but unhooked. Here's what will replace it if you get the kit. [IMG]
  7. mandolin Husqvarna
    Hungary
    SM 610 ie '09
    Thanks for the advice.Will think about it.
  8. 1lunger Husqvarna
    Bloomfield CT
    Lots of info on TE 610 power up on CH. just do a search. As far as installing the can, it will be a flow through ( no cat ) and the bike will want more air and more air means it will need more gas, hence the power up kit. Here's an option for the air box mod to allow for more air. [IMG] putting on that can means you should really at least do the power up so its not starving for fuel.
  9. mandolin Husqvarna
    Hungary
    SM 610 ie '09
    what is that? you open it up,and let more air to take in?
  10. 1lunger Husqvarna
    Bloomfield CT
    Yes, it's an EHSracing prefilter. It's the 4.5"x4.5" universal one
