ASV Inventions - Levers?
Discussion in '610/630' started by NothingClever, Apr 20, 2009.
  1. Does anybody know FOR A FACT which levers fit the 610?
    I called ASV today and they couldn't give me a conclusive answer :~
    Or maybe better yet, how do you bypass the clutch switch so I can just order a whole new perch :D .
  2. Motosportz CH Sponsor
    That is SUPER simple to do if you just want to order the perch.
  3. I finally got an adult supervisor at ASV to help me with P/Ns.
    BRAKE
    BLH03 - C5 Pro Series
    BHF32 - F Series
    CLUTCH
    CLM03 - C5 Pro Series
    CMF30 - F3 Standard
    CMF33 - F3 Pro Series
    Thanks, Kelly, for chiming in. Yeah, I found the answer over at SuperMotoJunkie.com......connect the two wires and you're done.
    (Right?)
  4. exit90a Husqvarna
    KY
    Do those part #s work for an 08' SM510R as well?
  5. Dunno.....that there '08 is newfangled technology for me :D .
    If you have a hydraulic clutch, you'll need different P/Ns.
    But fear not, the guy to call is the R&D tech. Listen to ASV's directory service (#5, IIRC) and he'll be able to square you away.
  6. exit90a Husqvarna
    KY
    Cool, thanks. I have ASV's on my CBR and, to be honest they are not functionally superior as far as I can tell. They just look/feel sooo good it's hard to resist.
  7. EWS Husqvarna
    Louisville, KY
    Did these levers bolt on without needing "modifcation"?
  8. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    I have a KTM lever on my 06 SMR clutch side, but have yet to conclusively determine which one fits the brake side. I had to loop the clutch safety sensor back to itself because the levers don't fit with that little switch in place. Now the bike starts in gear. I usually leave it in first now and say "suuuuuuuuuuuuuuuure you can go ride it!" haha. j/k
    If anyone knows a part number that fits the 06 510 I'd be grateful. Then it would match!
    I think the levers are superior, personally. I ended up with one because I snapped the OEM lever on a drop. Amazingly, the ASV (refurbs on ebay) were like half the cost of an OEM lever. The bike got knocked over after installing the ASV and the lever bent on impact. I finally got around to bending it back about a year later (lol), and it bent back with no trouble and no breakage. The cool thing to me is that they will warranty it even if you break it while bending it back.
  9. terrorkorps Husqvarna
    Italy
    Hi.
    I've installed an ASV F1 on my bike.
    You'll have some problem with the switching light...
    remove it!!
    :busted:
    bye from Italy
