So after talking to Arvin at ASV, we got some part #'s nailed down. Will be ordering them shortly and will report back to let you know if they fit or not. Looks like the clutch lever comes in a shorty but have not found the right lever for the brake in a shorty. ASV Clutch for Magura - CHF32-S ASV Brake for Brembo - BHF32
Google was tell this. I have those levers, they fit http://www.supermotojunkie.com/showthread.php?107861-ASV-F3-Brake-Lever-on-09-SM510R
Got the levers in over the weekend and the clutch lever went on flawlessly, although it has changed my engagement by about 3/8" of an inch further out. The brake lever, not so much. Looks like for it to work, I will have to dremel part of the Brembo housing for the lever to swivel and compress. Anyone else run into this issue at all? I have searched and did not find anything.
I dont remember had to some grind ASV brake lever to fit in there, at the point will be attached to... the image is only an example I mean a red circle around the area, where I had to grind a little that But when my clutch piston thing was worn is some how bad. I have to buy a whole new that clutch cylinder.... I am not sure whether it was causing the ASV lever or something, bad position, move position of that lever, not sure. Now days stock clutch lever and in brake lever is ASV, but some day they will going to chaince
Just spoke with ASV and they are swapping my lever out for the one that they say will work without modification. Will let ya know.
DVSKO, the BRF355 did not work for me without modifying the cylinder that holds the shaft of the master cylinder in with. I wish I had a picture. The BHF-32 did not fit at all, would've taken a machine shop to make it fit.
I found my lever packages. Here is some number Clutch CLH02-SK C5 series clutch lever only, short version, this is also black Brake BRC555-SK C5 sport series, brake shorty, black. Those will fit in 2010 model, but cannot remember if there needed some little modes to do
