Athena 300cc Kit for 2009 TE250
Discussion in '4 Stroke' started by Eoin, Oct 21, 2020.
  1. Eoin Husqvarna
    Gainsborough
    TE630, TE250
    Africa Twin AS
    Anyone fitted one? My TE has one fitted (83 mm bore) and now I'm looking at reassembling the engine, the deck height is nowhere near that suggested in the workshop manual. I've found the Athena instructions and no mention of deck height. Any feedback appreciated.
  2. Eoin Husqvarna
    Gainsborough
    TE630, TE250
    Africa Twin AS
    OK, so I've sent the head away because of a burned exhaust valve and a bit of marking on the face from the old gasket(s). The skim was 0.1 mm. The head guy did a chamber measurement for me after skimming, 13.4 cc. I've done multiple deck height measurements at 4 points round the piston, 0.6 mm seems the best measurement. I've also done the piston chamber measurement, the best I can get is 5.65 cc.
    Add it all together and I get a 12.14:1 theoretical CR. I'm guessing that the barrel will squeeze up a bit when the head is on because all I can do is push down on it manually while measuring. A bit of googling gives a 30% comprssion on the 0.4 mm base gasket, so 0.12 compression which would make the deck height .48 mm.
    That gives me 12.4:1. Reading some old posts, the original CR for the 250 was 12.9:1 and the Athena kit lowered it a little to 12.5:1, so I'm in the ball park. 0.1 mm gives .25 on the CR, so even if I've got something wrong, I'll be going from 12.5 to 12.75 CR, which is OK.
  3. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    You might give Feracci a call, he's still selling those 250 big bore kits (I think they're really a 285cc?) and can authoritatively tell you everything you need to know about it.
    Eoin likes this.
  4. Eoin Husqvarna
    Gainsborough
    TE630, TE250
    Africa Twin AS
    297 cc is the stated volume. I checked the CR because the deck height was not as the Husky manual, which must be to compensate for the smaller combustion chamber on the 250 head.
