ATTENTION! CRITICAL 2010 TC/TXC/TE info
Discussion in '4 Stroke' started by krieg, Nov 20, 2009.
  1. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    I pulled the valve cover on my '10 TC 250 last night just to see what was underneath http://www.cafehusky.com/forums/showthread.php?t=6324.
    This afternoon I put everything back together (or so I thought) and kicked it ONCE to start it up. After about 25 seconds of the motor running flawlessly, I notice a puddle of warm oil developing under the bike before my very eyes!:eek:
    I immediately shut the bike down and start investigating and find this lying on the jackstand:
    I immediately disassemble down to the valve train and start looking around to find the place that the "extra part" goes....
    When I took the valve cover off the first time, it was NOT obvious that the gasket was part of the process. Thank God it fell on the jackstand in an obviously visible location.
    Now you know! :thumbsup:
  2. Motosportz CH Sponsor
    Yep.
    I bet you took the cover off and the seal was on the cover, then set the cover on the stand and it fell off. Sound about right?
  3. BlueHusky144 Husqvarna
    Staunton, IL
    Great find! Thanks.
  4. john01 Husqvarna
    Powhatan VA
    Hey thanks for posting that and as always with pics.
  5. krieg Husqvarna
    Matthews, NC
    Many in the past
    That had to be what happened. :banghead:
  6. Slowpoke Husqvarna
    Southern Ontario
    Might not hurt to take a bit of high temp RTV silicone and glue that gasket to the valve cover..........??
  7. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    :eek::eek:
    Wow! That was close !
    Thanx for posting, wouldn't want to think of the consequences if you missed it.
    :cheers:
  8. Motology Husqvarna
    Australia
    Great insight, I'll be ready for that one now when I check top end.
    Thanks!
  9. restukey Husqvarna
    Bethesda, Md
    If you do go that route make sure it is applied paper thin. Any excess is going to end up down by the screen, most likely. Those type of machined mating surfaces normally call for an anaerobic sealant. Those sealants seal with the abscense of air and dissolve in the oil.
  10. ghte Husqvarna
    Bright, Victoria Australia
    Good pick up and great that you bothered to take pictures. Well done.
  11. DougW Husqvarna
    Santa Clarita, CA
    My issue is I had to remove the valve cover and remove this seal just to get the plug out. I've tried so many sockets and can't get down past that seal.
    Also, did you cut off that clip that attaches the breather tube to the valve cover?
  12. krieg Husqvarna
    Matthews, NC
    Many in the past
    I left it attached and just let the cover dangle.
