Auto compression release
Discussion in '4 Stroke' started by OM48, Jun 29, 2009.
  1. OM48 Husqvarna
    S.W. Pa.
    I have a low hour 06 TC510 with an E-start and 07 updates. It would start first kick after warmed up (HS starts). Last time out I couldn't start it by kicking and there would be a slight kick back where there was not one before. Slow circuit jetting may be slightly off but it didn't matter before. Any ideas? Thanks
  2. rajobigguy Administrator
    So.Cal.
    If you're saying that it is difficult to turn over or kick then yes something could definitely be wrong with the auto decompress.
  3. dirt rider x Husqvarna
    Australia
    so how does the auto decompressor work?
    The thin "lobe" beside the right side exhaust cam on my 04 bike seems to sit away from the cam when its stopped.
    I thought it should sit up against the cam when stopped or cranking and them move out of the way when it fires?
    there's a small spring loaded pin coming out of the side of the cam that pushes it away:excuseme:
  4. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    My 08 failed at very low hours (@10) on a Mex ride (what a pain), so "it can happen"
    for mine GP motos just replaced the mechanism and it has been fine ever since (100+ hours). R
    PS sounds like the same issues mine had as it failed.
  5. Motosportz CH Sponsor
    Yep, the lobe you are talking about is the decompression release. Centrifugal force spins it out of the way after a certain RPM. If it wears or is not working right it may be very hard to start your bike. Then you would have to do the routine like on an early YZF and get the piston just past DTC.
  6. dirt rider x Husqvarna
    Australia
    so at rest when you have the valve cover off where should the decomp cam sit? It has to be up against the cam proper doesn't it?
    Any thoughts why mine would sit away from the cam?
    The pin seems to push it that way.
    Pretty sure I have a problem as the electric start wont take it over compression anymore. :banghead:
