Backfire And Loss Of Power When Throttle Opened Up
Discussion in '4 Stroke' started by JerryP, Nov 6, 2020.
  1. JerryP Husqvarna
    2011 TXC250
    Hey Guys
    Very new to this so apologies if this is not the right way or place to do this. Just got back from riding my 2011 HUSQVARNA TXC250 today and found the bike was lacking power off idle and backfiring when I twisted the throttle. Barely made it back to the truck
    I hope its nothing sereious but when filling up the tank I did break the nipple on the gas cap although I could still hear the little plastic bearing moving inside
    Valves where done not long ago. Always fresh gas and clean filter
    Is it possible be breaking the cap is starving the motor
  2. cordia Husqvarna
    Durban SA
    TXC 310 2013
    KTM GasGas Honda
    Hi no this not starving the motor u have petrol filter before the pump
    first try ... replace the TPS back on the timing chain... is the bike hot then normal ?
    check the inlet valves too.. but a new petrol filter in.. if the the bike was used for a long time then maybe is time for a new injector too
  3. LBM. Husqvarna
    St. Johns Newfoundland Canada
    2011 TE310
    1975 Honda CB550F
    My high hour 11 te310 acted like that last year after a wet trail ride. removed the gas tank for insp and found both of my coil wire harness wires had the insulation rubbed to the bare wire against the tank. also found my wire connector from my stator (i think) had overheated some time and melted and almost completely shorted out. cut that connector out completely and used good male to female blade terminals to repair. don't terminate them all the same or it may get confusing if all 3 (or 4) are disconnected at the same time. the harness on a old bike take a beating. Ran fine after wires repaired.
    good luck!
    11TE310 with 333.3h
