250-500cc Bad vibrations and cylinder crack
Discussion in '2 Stroke' started by Jay Hayward, May 18, 2013.
  1. Jay Hayward Husqvarna
    2009 WR 300
    Hi Guys,
    I have recently purchased a 09' WR 300, it is a big change from my last ride a KTM 540 exc but heaps cheaper to register in Australia as it is less than 301cc, anyway I'm having trouble coming to terms with the amount of vibration in the frame, I've checked all mount bolts, main bearings, filled handle bars with urathane and checked bar isolating rubbers- all ok
    Is there anything else to check or is this normal for a 2 stroke?
    Also I have removed the head to adjust the PV and identified a small crack between the large and small exhaust port, can this be repaired with a sleeve and are there big bore kits avaliable to increase bottom end?
  2. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    You can have it welded and re plated. No sleeves on the newer huskys they use a nikasil plating.
    As for vibration not too sure. The 300 will definitely vibrate more than your ktm 4 stroke though.
  3. broken biker Husqvarna
    1994 TE 610 2012 WR 300
    my 2012 wr300 cracked the barrel between exhaust & sub port.the dealer admitted this problem only happens on the 300.3 successful warranty claims 4 top end failures & one 4 stator failure ,all with less than 700km & it is still not fixed.put a 250 barrel on or sell it
