Baja Designs clear lens LED taillight/license plate holder
Discussion in 'General (Main)' started by Philbilly, Apr 25, 2010.
  1. Philbilly Husqvarna
    Mount Pleasant, NC
    Check it out, PN 059072 (about $60) installed on my 2009 WR125. Some cutting required but it looks good. Is this the taillight I read about getting moisture in and failing? Everything looks pretty well sealed to me.
      File size:
      84.7 KB
      45
      File size:
      86.1 KB
      50
      File size:
      83.9 KB
      68
      File size:
      45.9 KB
      45
      File size:
      31.2 KB
      46
  2. rajobigguy Administrator
    So.Cal.
    It's not as well sealed as it looks. I've replaced the light assembly on mine because of corrosion. On the lighter side though, at least it's not expensive. I was thinking about ordering another one just to have a spare because even though they are pretty reasonable they don't ship all that fast.
  3. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    12 RS520, CRF150F/230F, YZ250
    I have had the same one on my TE450 for over a year with zero problems, You just put to much water on yours Rajo. :D
  4. Philbilly Husqvarna
    Mount Pleasant, NC
    Cool...I trail tested it yesterday in some greasy NC red clay-no problems. Does it need any kind of sealing or maybe the lens taken off to dry after washing?
  5. seymore Husqvarna
    Boise, ID
    Mine failed after a few rides in wet muddy condition. Baja Designs sent me a replacement, which I used clear 100% silicone to seal around the wire grommet and the edge of the clear lens where it's glued to the back plate.
    I haven't had a problem since then.
  6. Philbilly Husqvarna
    Mount Pleasant, NC
    Got it, thanks!
  7. I've used 3 of them, when the third burnt out I replaced the LED with a Whellen emergency strobe LED, way brighter and has been on my '05 for years with no issues although you have use a resistor to dim the light for your running light. I just installed the same setup (BD dropdown and Wheelen LED) on my '09 TE. Maybe I just tend to abuse things because I have friends that have used the BD LED without issue for years but if it does crap out on you the emergency LED's are about the same price and much, much brighter. I did get pulled over at night once with the setup, the cop said he couldn't see my plate (too much angle on the dropdown), he said he didnt know if it was legal or not and then said goodnight without even checking my liscense, insurance, etc...
  8. Philbilly Husqvarna
    Mount Pleasant, NC
    Thanks for the help!
