We are looking for replacement bar mounts for a 2013 WR300 to fit 1-1/8 Renthal bars. Would like to get away from rubber cones, but we are okay with rubber if that's all we can find. What are our options? Any suggestions?
Why would Renthal bar not fit into the original bar mounts? Are they for 7/8" bars? As I know, since 2008, all the WR/CR should be delivered with 1-1/8" bars. If you want to get rid off the rubbers, see post above. If you are looking for 1-1/8" bar mounts te replace 7/8" bar mounts, apart from the original ones, they are plenty of them. Look at Neken, ProTaper, Renhtal, alloy-ultima, BRP and so on. Another, more expensive way to go is the X-trig upper clamp with rigid or PHDS bar mounts. jeanjean
