So i want to put bar risers and or taller bars on my sm610, but with the stock clutch cable and its routing i doubt that can happen, so i was hoping i could get some help with a solution. Also would i need a longer brake cable as well? Also if anyone does have a solution, could i see some pics?
I've got 2" Rox Risers under the pad and CR high bend bars. Get a Motion Pro cable, its 2" longer than OEM and everything else fits fine. You might need to reroute the " enricher lever ", but that's it and I'm not sure you'll even need to do that.
The Barnett cable is also a couple inches longer, and is longer lived than the OEM (the best built cables there are, in my opinion). I haven't used the Motion Pro so can't comment on a comparison there.
+1 on the Barnett cable....I bought one recently. The nice part is the end of the cable has a pre bent metal collar and it puts less stress on the cable. Made the clutch pull seem easier too. But I have also not used the Motion Pro cable so I can't compare the two.
