Barnett Clutch Cable
Discussion in '610/630' started by jerbear610, May 25, 2010.
  1. jerbear610 Husqvarna
    Sacramento,CA
    14' WR300, 11' TE511, 06'TE610 sold
    11' Husaberg FE570, 15' Beta 300RR
    I just got a Barnett Clutch Cable and the ball end that connects to
    the arm down on the motor is bigger than the stock cable so I'm
    wondering if anyone else has used these and if so how do you connect it
    to the arm? Here's a pic of the two. Jerry
  2. Motosportz CH Sponsor
    use a screw driver to slightly open the steel flange that holds it.
  3. miketv Husqvarna
    Columbus, Ohio
    Make sure you check the alignment of the bracket that holds the cable to the clutch arm. Some brackets were mfg slightly out of alignment (mine) which caused the early failure. Also add a small dab of grease to the ball end, check the slot on the clutch lever for interference/drag when the lever is pulled in and you should be GTG :thumbsup:
