250-500cc Basketcase 1995 WXE360
Discussion in '2 Stroke' started by banana944, Apr 29, 2016.
  1. banana944 Husqvarna
    Central MA
    2009 SMR510, 1996 WXC360
    01 YZ300,01 KDX200 both street legal
    So I picked up a 1995 WXC360 today. Always wanted a 360 since I had my 99 WR250. Great bike always regret selling it. Have had plenty of dirtbikes since then but the only Huskys since are a pair of SMR510s.
    Onto the the 360. Its a 1995, seen plenty of use, very tired. It started for me in just a few kicks. But it didn't take as much force to kick as I anticipated... assuming a very tired top end. Bike is all there, suspension is tight, but its ugly. Plastics beat and no good. Frame has been JB welded at the subframe bolt, JB weld at the coil mount, missing motor mounts. One fun problem is that you get shocked through the handlebars... something must be shorting to frame.
    Bike came with another complete roller WXC360 minus motor unfortunately. Pretty much just bought the bike for the motor. What do you guys think, rebuild it or pluck the motor into a newer chasis?
    Whats the parts availability for the bottom end of the 360?
    NCSteve and juicypips like this.
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    parts availability is pretty good for everything but plastic...if you dont like those ill buy em for a fair price..
    juicypips likes this.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    If you have a newer chassis drop it in.
    Plastics are $$$ but forks frame wheels arnt worth a bean. I would keep an eye out for 250 engine for the rolling chassis n rebuild the 95 with newer subframe tank seat n plastics.
    BenM and NCSteve like this.
  4. justintendo klotz super techniplate junkie
    i usually never see em around, and if i do no one wants them being fleuroscent..
  5. banana944 Husqvarna
    Central MA
    Yeah if I was pursuing the motor in this chasis then I would look to swap subframe to at least 00-04 style. Crankshaft kit or rod still availabe?
    Justientendo if you are interested in plastics message me.
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup KTM con rod kit for 360/680 1997 135mm fit the code to look for is 54730015000 the box is very tatty so I may of miss typed.
    The big end pin is a few mm shorter but I've had that rod in my 02 360 for a few years now and it's spot on. Yeah that's right my husky was part KTM before the take over
    As for crankshaft not sure.
    rancher1 likes this.
  7. banana944 Husqvarna
    Central MA
    Awesome, that's good to know about the ktm rod. I assumed if the husky one wasn't available another could fit. Thanks for saving me the homework.
  8. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    I've pics of my crank rebuild. Juicypips saved the day for me with the KTM rod tip. Thanks again, Jucypips!
  9. banana944 Husqvarna
    Central MA
    Darrel I just read through your threads. Alot of good info I appreciate it. So with your install of the KTM rod, you did not have your head modified for squish, correct?
    Still looking for a kickstand? If so message me.
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Well you don't have to play with squish if your happy with it not working.
    I on the other hand have mine @.55 thou.
    Yes I had to have the head machined but I left the dome untouched.
    The rod is a straight swap.
  11. banana944 Husqvarna
    Central MA
    I guess I should have specified the dome shape. Thanks for the clarification!
    I hope to have more time to play with it this week. Do a compression check, try to track down the cause of the voltage at the handlebars. Looking quickly I saw no wires chaffed or anything too obvious, but assuming the JB weld near the coil mount could be causing an issue.
    May pull the motor and drop it into the other frame. But really need to focus on finishing up my Yamaha YZ300 first.
