Battery Charging 14 TE 310
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by 2wheeler, May 17, 2015.
  1. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    Read some threads on charging/maintaining. Want to check in with you guys before hooking things up.
    I have a CTEK with Motorcycle Mode and the stock Yuasa.
    It appears using the pigtail with battery in bike is not so good.
    So, remove battery from bike, hook up the alligator clamps, set to Motorcycle Mode and leave as is until next ride?
  2. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    That is essentially what I do, but I use a Battery Tender
  3. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    What is the issue with a battery tender and the battery still being hooked up? I do that over the winter.
  4. AlwynMike Husqvarna
    TE310R
    Honda CRF 250x, Suzuki GS1000
    Me too
  5. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    There was discussion of the fuel pump actuating with battery in bike and charger connected. I guess there is one way to find out. :D
    I wonder if the models without an ignition switch are affected? Without a keyed ignition switch does that mean the system is 'hot'?
    Would rather just connect the pigtail and be done with it.
  6. AndrewS Husqvarna
    2009 TE250 (sold)
    Mine doesn't have a keyed ignition, but I don't get the click some have mentioned.
  7. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    Many of us keyless have the clicking and flooding feature if using a LI battery. I posted videos awhile ago. Just the nature of how companies wire the bikes. Even the new bikes have this "feature" from another post. A little lame that no vendors/manufacturers, geniuses have addressed it with a comment on why this occurs at least and a solution/fix, shy of battery removal to charge. I won't risk losing my house to a fire and remove the battery from the bike.
  8. AndrewS Husqvarna
    2009 TE250 (sold)
    Interesting. I'm using the stock battery, so that may be why I don't have the issue.
  9. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
  10. AndrewS Husqvarna
    2009 TE250 (sold)
    Ah, okay. Now I remember this issue. I have no idea why it's not consistent. I don't remember my frame # offhand, but it (2013 TE310r) was later than those requiring the starter update.
  11. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    Strange indeed. So the best way to avoid a potential issue is to remove the battery before charging. How about we disconnect the cables, shield the cable ends with rubber hose or vacuum caps then attach the clamps?
  12. Shovelhead85 Husqvarna
    Northern NorCal (California, USA)
    2014 TE 310R
    XR400R, '75 DT400B, FLH Shovel, CT90
    Hey John- did the speedo display ever come on? ...or did the headlight? I'm wondering if, since its a keyless system, that the ecu is detecting a high enough voltage (therefore wrongly thinks the bike is running because the alternator is putting out) and kicks the extraneous stuff on (speedo, lights, horn, sigs).
    But it seems that the fuel pump relay is cycling on and off rapidly, as someone reported. And somebody else reported a "flooded" bike, meaning the injector was getting a signal [wow!].
    The 449/511's are keyless too... wondering if anyone has seen a problem.
    weird.
  13. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    I didn't see or notice the instrument lights.
  14. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    love how the nuts on the battery terminals drop out of reach of the bolt when disconnected :rolleyes:
    battery freshened = .5 hp on the butt dyno today :D
