johnsweet
Don't ask me how but I hooked up the new EarthX battery backwards. I said this looks easy enough. They provided some sticky rubber pads to help position the battery inside the box. Well I stuck them on the wrong side, put the battery in and proceeded to hook up the cables. Thought it got a little hot but kept on screwing the bolts/screws down until I started to see smoke. Quickly I reversed the process and duh finally noticed the positive was hooked to the negative and the negative was hooked to the positive. Was probably hooked up for 10 to 15 seconds. I expected the worst as the coating on the outside of the alternator wires had melted. Colored wires were still OK. Turned on the ignition key, all lights came on and started and ran OK. My question is what else could I have screwed up? Don't tell me know one else has ever done this
