Bazzaz system?
Discussion in 'EFI/carb' started by dirtrider_gr, Nov 28, 2012.
  1. dirtrider_gr Husqvarna
    Athens, Greece
    Ktm Adventure 950 '04
    Hi!!!
    Anyone try the Bazzaz system?
    Any thoughts?
  2. dirtrider_gr Husqvarna
    Athens, Greece
  3. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    I've used them on streetbikes. It works great but they do not develop individual maps for different pipes like Powercommander does. The beauty of these is when you use it with a wideband O2 sensor and the autotune module. It creates an excellent map based on your bike and setup and makes WAY more intricate adjustments than the JD tuner does. But it is not nearly as user-friendly as the JD, and it is a way more expensive setup. You can also add a map select switch and have an optimum performance map and a fuel mileage map and switch on the fly. Pretty cool.
  4. ray_ray Mini-Sponsor
    The Philippines
    Price: $324.95....
    I'll be passing on this unless I can eat it if hungry ...
  5. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  6. kairles Husqvarna
    Antelope, CA
    2008 SM610
    2006 hayabusa 2010 R1
    anyone know if the Bazzaz for the TE630 will work on an 08 SM630?
