Hi all, I have a '98 Wr360 with mikuni TM 38 stock carb, it was too rich so I checked the jetting, this was the situation:
main 340 (brand POLINI)
pilot 27,5
needle 6AEJ03-64 1st groove
from the manual I found the standard jetting for this bike is the following:
main 430
pilot 40
needle 6AEJ03-64 2nd groove
so only the needle was correct, but the main and pilot jets was leaner than the std, but the engine runned rich, so it was strange...
I trusted the manual and bough a 430 main jet, 40 pilot jet and a new needle thinking the old one could be worn
the first thing I noticed was the old pilot jet is broken...
but the stranger thing is the new needle is longer than the old one... it is crazy! they are the same needle, both of them have the same code impressed over the body, both are genuine MIKUNI parts with the autenticity mark... I can't found an explanation...
I think they have also a different conicity, but I'm not sure about this..
I tried the bike with new jets and both the needle, the pilot jet run well, at low throttle opening runs well, a lot better than before, but from middle to full throttle it is a disaster... worst than before, too rich, at full throttle is almost unusable with the engine that struggles to take more rpm...
why the standard jetting won't run ok? even assuming the old part are weared, now I have all new, where can be the problem?
and why 2 needle that should be identical are so different?
I know the better choise is to throw away the mikuni and put a keihin PWK on it, I have plenty of jets and needle for keihin, so it would be easy to find the correct setting, but I can't buy it now and I want to use it with the mikuni carb for now...
thanks to all
pilot 27,5
main 430
pilot 40
thanks to all
of course if it is the new one won't go in so... now you know
