As the title said, I noticed my peg mounts are a little bent. On both sides the bottom section of the mounts are angled down some. I noticed this when the normal size cotter pin would not fit in. Is this common? I am not doing pro level supercross but maybe all the roots and ruts have done the damage? I was wondering if it would be safe to take a hammer and just bend them back up a little? Or should I heat them up with a torch first? Or do something different?
man where do you live, id like to ride where you do......a broken wheel hub, now you have bent footpeg mounts...
