Best longer clutch cable for TE610??
Discussion in '610/630' started by BiG DoM, Nov 20, 2012.
  1. BiG DoM Husqvarna
    I fitted a new OEM clutch cable about 5 months ago and while on a 2000km ride in some very remote areas discovered it fraying at the lever. Managed to nurse it home while kicking myself that I had forgotten a spare I had. I want to replace it with a stronger and longer cable - who sells the best? My other alternative is to have a few made up by cable maker guys.
  2. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    i havent used it because i cant find anyone stocking it here but many recommend the barnett. part no #101-37-10610
  3. shootis Husqvarna
    Dedham Maine
    2009 TE610
    DR650
    Since we're on the subject of clutch cables, how does the longer than stock cables route?
    My bike has it on the outside of the radiator but I bought the bike used so I'm unsure of the routing.
    I bought the Motosportz cable and have emailed them and started a thread in the Motosportz forum with no response.
  4. tunp Husqvarna
    07 TE610, 13 TE449
    KTM 990, 02 FLHTPI HD
    I have and am using the motosportz cable, no issues. My routing is on the back side of radiator, coming up in front of tank.
  5. 1lunger Husqvarna
    Bloomfield CT
    I believe the Motosportz one is made by motion pro for them and its a good one! 2" longer and much better over all product!
  6. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    Hi Dom --Cable Guy in SA makes them up --just take your old one and ask that they make a new one 50mm longer. They also put in a thicker inner cable and stronger casing for it. Paid about R170.00 --Same day service ---
  7. BiG DoM Husqvarna
    Thanks - what I thought (we have Cable Man near me).
  8. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    my clutch cable has gone. i cant get the barrett cable here but can get the motion pro 10-0123. does anyone know if this cable is the same length as the oem cable or longer? i cant find the info anywhere.
    cheers
    edit: pretty sure from googling its the same length as the oem cable. i have a scotts damper which lifts the bar about an inch. not sure if the standard length will be long enough.
  9. 1lunger Husqvarna
    Bloomfield CT
    I have the motion pro 2" longer one, but not sure of the part number
  10. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    where did you buy it?
  11. 1lunger Husqvarna
    Bloomfield CT
    Motosportz (360) 597-4364
