Best paint for exhaust pipe?
Discussion in 'Vintage Restoration Projects' started by mci-owner, Nov 29, 2013.
  1. mci-owner Husqvarna
    Pittsburgh, PA
    1979 WR390, 1976 WR360, 1974 Mag 250
    2013 TE310R
    Dose anyone have any sugestions for the best black paint for an exhaust pipe.
    I have a FMF pipe on a 74 250 Mag that was sprayed with some sort of clear that has gotten pretty ulgy, and I want to freshen it up. I can soda blast the pipe to get a good bond.
  2. disonny Husqvarna
    upstate ny
    73 360 wr/rt, 75 wr250 78 cr250,
    83 wr250, 84 wr400
    It's really personal preference. I like the semi gloss finish. I use high temp engine paint.
  3. mci-owner Husqvarna
    Pittsburgh, PA
    2013 TE310R
    Yea I did some research on the site and think a inexpensive VHT may be the way to go, as I will be riding it. I believe a clear was put on the pipe new. It looked great then, now mud just sticks to it and it always looks dirty. Here is a new pic and after Mid Ohio 2013 MAP Pictures 037.jpg 74MAG.jpg 74MAG.jpg
  4. mci-owner Husqvarna
    Pittsburgh, PA
    2013 TE310R
    The pipe did clean up but no longer shiny and mud seems to be embedded in the coating.
  5. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Ceramic
    Pay once
    Cry once
  6. mci-owner Husqvarna
    Pittsburgh, PA
    2013 TE310R
    Is a ceramic coating something I can do, or is that some thing a special shop dose?
  7. adam6402 Husqvarna
    Tulsa, OK
    None
    The VHT spray paint I have is Ceramic. Once sprayed, then you need to follow the curing process.
  8. Big Timmy Husqvarna
    (South Eastern) AZ.
    I've made expansion chamber pipes for over 200 bikes and I never paint them. I install the pipe and let it get hot and wipe it with some sort of Vegetable based Salad oil. Seriously the mud doesn't stick and it will glaze over itself. Easy to scotchbrite and redo it when needed as well. It stops the rust and works everytime. Paint just makes it tacky and sticky to the mud. Why do you think the 2 stroke pipes most of the time nowadays are Nickel or Chrome plated?
  9. auto Husqvarna
    NJ,USA
    too many
    Kal-guard! I use it on my cases also.Tough stuff,use the adhesion promoter.Gas has no effect on it.You can get gloss,satin or flat.
  10. mci-owner Husqvarna
    Pittsburgh, PA
    2013 TE310R
    Thanks for the replys, and info.
  11. bower100 Husqvarna
    Wilmington, DE
    '83 250CR - '07 TE450
    TY350Trials-BetaRev3-'77RM250-'80YZ
    Scanning the tech posts, ( I'll be working on a '83 250CR I just bought in Jersey). Can you tell me what KalGuard paint your using ? Googled KalGuard and got a bit lost in the info. Thanks, dave
  12. auto Husqvarna
    NJ,USA
    too many
    Go to KG industries I use 2400 gun coat with their 4000 pre treatment
  13. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    other choice ! nickel ! :thumbsup:
  14. mci-owner Husqvarna
    Pittsburgh, PA
    2013 TE310R
    Love that nickel finish.
  15. Big Timmy Husqvarna
    (South Eastern) AZ.
    There you go! It doesn't take a Mental Giant to figure this one out. Nickel doesn't cost that much either. Great protection, good looks, and no sticky, tacky surface.
  16. Michel Dufayard Husqvarna
    France
  17. visiteur1948 Husqvarna
    france Europe
    husqvarna only
    price pipe by french boy is crazy
    ( pilot boy ):banghead:
    this pipe 125=700 euros !!(us $ 800 !):confused::confused:
    no my pipe and exhaust 125 = USA !
    = $ us 250 + chipping = $us 50 !:D:D
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    try some satin black etch primer, works a treat, paint it once a year
  19. Desmoducky Husqvarna
    1976 WR360, 1972 CR 450
    1998 Ducati 916
    Has anyone considered using Duracoat? It is meant for refinishing firearms so it's designed to take the heat.
    Desmo
  20. mci-owner Husqvarna
    Pittsburgh, PA
    2013 TE310R
    I have sent the pipe out to be plated, "Zinc/Nickel" finish, which should come out a bronzey dark with iredesent shades of gold. I will post pics when done. This is a finish that is used on undercarriage parts on trucks and equipment. The bike has gold wheels and wanted a dark finish to reduce the bling factor. should cost $150 to have done.
