seymore
I was doing some maintenance on my 08 TE450 and notice all the engine oil on the frame near the upper shock mount that had come from the K&N filter attached to the engine vent hose.
I know the large does oil comes from events (crashes) such as inverted and right-side lay downs.
I removed the vent hose from the intake boot about a year ago after noticing the engine oil accumulating in the intake boot. I went with K&N filter and located it just in front of the air box. After seeing the oil/dirt mess, there has to be a better solution. I searched the forum, but didn't any different solutions.
My WR426 had the vent hose routed up near the steering head and down along the down tube where it drip near the skip plate.
I'm thinking of routing the hose like the WR and installing some type of an inline filter to keep dirt out.
Does anyone have a better idea or proven solution?
I don't recall if there is a baffle in the valve cover, if there is it's not very effective.
