best tps setting for 2011 TE310?
Discussion in 'EFI/carb' started by Green Mtn Rider, Sep 1, 2012.
  1. Green Mtn Rider Husqvarna
    Vermont
    2011 TE 310
    I have now upgraded my 2011 TE 310 with the 2012 TXC310 injector and ecu with the JD tuner, also added the Akrapovic exhaust. Just got the I-Beat software & cable so I can adjust the tps setting. My question is, what is the best tps idle setting in MV and % of wot for this setup? Also if anyone has the same setup what settings do you have for the JD tuner?
  2. R_Little Husqvarna
    NJ
    my 2010 Te250 ran best at 102%
