250-500cc best way to remove crank...360 kicker issues
Discussion in '2 Stroke' started by justintendo, Oct 16, 2013.
  1. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    quick question...after splitting the cases on a 360, the crank stays in the lh case...does it need pressed out? kinda feels like it does..
    im dealing with the dreaded 360 kicker issue...the idler gear that sits behind the clutch basket is destroyed along with the small drive gear on the back of the basket...the boss that the idler sits on is shifted and cracking..the allen bolt that holds the idler in place was loose....the rest of the trans and kicker assy looks great...has anyone rewelded this?
  2. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    Just did the crank on my 2000 360 and had to press the crank out. I used a case splitting tool to press it out.
    Can't help you with the other stuff but good luck.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    no you can leave the crank in if the conrod is good, you can get access to all the kiskstart shaft with it in its just a little bulkyer, masking tape the conrod to the jug stud to stop it thrashing about.
    p.s. kickstart issues it that the web cacked on the crank case or you just sheered the shaft?
  4. justintendo klotz super techniplate junkie
    i want to put in fresh mains as one of them has a tick of play...so i was wanting to get the crank completely out...the rod is good. yes the case is starting the crack and the boss for that idler is getting pushed forward....ruining the small gear on the back of the clutch basket...
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    right yeh just get a blow lamp and gentally heat the entire area around the main bearing keep going for as long as you get board as the ali will wick the heat away through the case, then either tap it out with rubber hammer or if you get lucky it may just slide out. dont pry with screwdrivers or get heavy with the hammer
  6. justintendo klotz super techniplate junkie
    thanks pips....i was thinking about doing that...just like changing a bearing..
    juicypips likes this.
