250-500cc Best Year for the WR300?
Discussion in '2 Stroke' started by banana944, Oct 23, 2015.
  1. banana944 Husqvarna
    Central MA
    2009 SMR510, 1996 WXC360
    01 YZ300,01 KDX200 both street legal
    Alright guys, had a 2010 SMR510 a couple years ago, loved the bike, hated to get rid of it. Well a couple weeks ago I picked up another SMR510, a new to me 2009. Couldn't fight the urge anymore.
    Now even a few more years back, I had a 2000 WR250 and I LOVED that bike. Awesome for the woods riding here in New England.
    So come spring time, I will be looking to add a WR300 to the stable. I used to be smarter on the subject, but I know there were some changes to the WR300 over the years. I know the ignition system changed around 2011?
    So knowing what we know now, what year is the best/most reliable?
  2. giantjoe Husqvarna
    Canadia
    2010 WR300
    My 2010 has been bulletproof. Original ignition, KYB forks.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    The older than 2010 ignition is more reliable and if your open to a 250 over a 300 the 250 seems to be more reliable as well. I'm really happy with my 09 wr250, it has the 50mm open chamber Zokes. The 50mm zokes aren't great until you have them re-valved. I had LTR do my forks and shock and with the addition of a Lectron carb and Gnarly pipe it's a perfect woods set up now. SKF fork seals are also an improvement worth the money. No matter which one you get adjusting the clutch arm geometry at the engine will greatly improve the feel of the clutch, it's done by setting the length of the pushrod in the center of the clutch basket and it costs you nothing.
    Borntoride71, Tordep and PowerKord like this.
  4. banana944 Husqvarna
    Central MA
    Awesome, all good info. I would not be opposed to a WR250, but pretty set on the WR300. Just like the SMR450 vs the 510, sure the 450 has enough power... but why not just go all out?
    I have heard that a Lectron carb with a G2 throttle is a great upgrade.
    Besides the ignition, not much changed for the engine/electrical over the years correct? Suspension changes happened along the way?
  5. lankydoug Husqvarna
    MO
    WR
    TM 300en
    The Lectron makes it so much easier to ride, I don't see the need for the G2, I would actually prefer a quicker shorter twist/travel throttle with the Lectron if anybody made one. The Ducati ignition that came along around 2011 is not terrible, only a few people had problems with them compared to no problems at all with the older ignition. The KYB forks are good and the Sachs shocks are good as well, some had piston seal failures, (mine did after 2 years) I used it as an excuse to get it re-valved and now it's really good. I've got my bike dialed in for me and so far I haven't found a new bike of any make that I like better mostly due to the fact that Italian WRs are great if you are tall. If I could ever come to terms with a 4 stroke I'd get a new 2010 and up YZ450 but that's another thread.
  6. banana944 Husqvarna
    Central MA
  7. Scott Howard Husqvarna
    Victoria, BC, Canada
    FE350s, 701 enduro
    650 V-strom, Beta 300RR
  8. Scott Howard Husqvarna
    FE350s, 701 enduro
    Oops, never mind, I just looked at the page and it's 34 to 40 mm.
  9. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Borntoride71 likes this.
  10. banana944 Husqvarna
    Central MA
  11. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I'll 2nd that :thumbsup: The reason I like the G2 throttle so much I think is because I also have a Rekluse clutch. That combo, Lectron&G2&Rekluse, gives me a very wide seeming, very controllable, smooth power band. Kelly also includes a high quality throttle cable which is the icing on the cake.
    Also the combo allows me to run taller gearing, now 14:49, which makes for scary top end while still having a trench digging, u-turn now! 1st gear :cheers:
  12. banana944 Husqvarna
    Central MA
    Now another question, I would be hoping to find a bike that is street titled in another state, as MA is quite the process.
    Did all WR300 come with the computers/gauges on them? Some I have seen with, and some without. What about lighting for turn signals and brakes? Are they all prewired and capped, or does it involve a wire harness swap?
  13. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    There's a factory kit.
  14. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Yeah, depends on the bike and the deal. Some came with the enduro kit installed, some it was in a box and some didn't have it. Mine was new in '14 from the BMW dealer and didn't include the kit. :cheers:
  15. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    My 2011 came with the kit in a box. I never installed it....yet.
  16. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
  17. banana944 Husqvarna
    Central MA
    Thanks for all the info thus far. Anything else to add?
