big foot problems
Discussion in 'General (Main)' started by WHITEROCKET5.9, Jun 21, 2011.
  1. WHITEROCKET5.9 Husqvarna
    central illinois
    ok so i seem to get my foot caught under the gear shifter quite abit and usually at bad times. generally its when im commin out of one of the corners shifting and getting ready to hit a jump or whoops.... you get the picture.anyone else have/had this problem and what did you do to fix it? i tried riding with my foot back more on the peg but that isnt cuttin it.
  2. ray_ray Mini-Sponsor
    The Philippines
    Is the shifter lever too low? Are your toes pointed at the ground when you are riding or shifting?
  3. WHITEROCKET5.9 Husqvarna
    central illinois
    now that you said that, i think that my foot is angled down some. ill have to check that out
  4. ray_ray Mini-Sponsor
    The Philippines
    Having my toes pointed downward is scary to me ... I like my toes parallel to the ground or if my toes are downward any and sitting on the front half of the peg, they will be well above the frame of bike....
    I usually pick my entire foot up to change gears... Toes taps on the shifter do not work so well for me ...
  5. BadMotoWeazal Husqvarna
    Alabama
    Learning to ride on the balls of your feet will help with the toes pointing down.
  6. J.R. Husqvarna
    Northern Utah
    450 Supermoto! and a BUNCH 'O parts
    But then you would have to move your foot a lot more to shift/rear brake, rather than just pivot your foot to operate either level... Right?
    BadMotoWeazal likes this.
  7. BadMotoWeazal Husqvarna
    Alabama
    Depending on the terrain that you are riding on... Deep ruts, rocks, tall roots, log crossings, better have your toes up. Sometimes you have to lean back on the bike, that would be a time for me to shift weight & move my foot so that I've got the shank of my boot on the pegs with my bum over the rear of the seat/fender, but my toes are still up. I guess that my feet are pretty much always moving to brake, shift & move body positions but it's second nature to go to the balls of my feet in attack position now & I don't think about it.... But I always try to not let my toes point down, nasty stuff happens.
  8. HuskyT Moderator
    Corona, California
    The obvious question that has not been asked.... how big are your canoes?
    I'm a size 12 and would enjoy a longer shifter arm... thinking about the ZipTy racing 10mm extension.... I have also relocated the shifter up or down on the splines... move it up or down about three splines at a time on teh shift shaft . ride the bike and see how it feels... timing your shift on a track can make or break wether or not you clear a jump or roll it... if your foot is "Stuck" it can really throw you off.
    Right now, I am up two splines from flat and actually hate it.... I'm going back to a more laid down shifter arm...
    Also... try and get up off your but as much as possible... even when your tired... your foot angle and rocking on the peg helps greatly...
    Logan and I just started pretend shifting his KX 65 last night... I'm teaching him how to rock on the pegs right now..while using the clutch and his foot... . may seem silly but throw it up on a stand where you can rock the bike and try different postions on the splines to see what feels best for you!
    T
  9. WHITEROCKET5.9 Husqvarna
    central illinois
    thanks for the help guys [IMG]..well i have size 13 tennis shoes but managed to fit in soem size 12 msr's. im headin down to the garage rite now to fart around and probably hit the track for a few laps so ill chime back in with what i find out
  10. BadMotoWeazal Husqvarna
    Alabama
    I know boots cost a lot of cash these days, but getting a pair of Garne SG's or the Sidi that have a hinge at the ankle has help me a good bit with my foot placement. My kids (7 years old) boots are soooo stiff & although I have tried to oil them & work them it is impossible for him to move his foot & have any feel.
  11. WHITEROCKET5.9 Husqvarna
    central illinois
    bad, thats the exact problem my son has with his shifting. and yes im splurging for some garnes soon myself, that may be as much of the prob as anything else from the other boots ive seen compared to my msr's.. mine seem pretty big n bulky compared to the other higher end brands
  12. ray_ray Mini-Sponsor
    The Philippines
    The worst boots I've seen are the ones with the big Bozo tip on the end of the boots... These types are very hard to get under the shifter...
    WHITEROCKET5.9 likes this.
  13. BadMotoWeazal Husqvarna
    Alabama
    I got a new pair of SG-10's for $309.00 shipped. I thought is was a smokin' deal.
  14. WHITEROCKET5.9 Husqvarna
    central illinois
    well i rode and wore myself out lol my foot is definately pointed down to get it under the shifter ill be moving the shifter up some tomorrow evening
  15. HuskyT Moderator
    Corona, California
    I have Alpine Star Tech 6's and love them... well broken in... and a buddy just gave me a brand new pair of the exact same boots for free....I'm covered for the next little while... That is a smoking deal on SG-10's...!
    T
  16. HuskyT Moderator
    Corona, California
    Think about your riding position as well and make sure your balls are up on the tank... helps with the angle of your foot... plus your non-turning Husky will turn better!!!
    T
  17. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I wear size 14 Gearne G 10s and I have hit neutral a few times, usually when I preload and I'm about to hit the far side of a creek bank or a jump (not a good time for this to happen). I have my shifter up pretty high and low and back Fastway pegs but the problem seems to be that the shifter hits the boot about mid-foot instead of at the toe end. My boots are new so I've been wearing them while cutting trails with a chainsaw and that has helped a lot in breaking them in and making them more flexible. A longer shifter would help but 10mm is not enough, I think it will have to be a combination of pegs, boots, shifter and maybe adjustments in stance to completely solve this. Tall bars, tall seat, low pegs, long shifter, good boots, modified brake pedal all add up and $700 later it's like the bike was made for you. People tell me all the time that they wish they were tall... be careful what you wish for. [IMG]
    twolane and WHITEROCKET5.9 like this.
  18. WHITEROCKET5.9 Husqvarna
    central illinois
    t, ive been moving back and forth tryin to find the best spot for me for turning, ive gotten kinda gunshy in the corners the last month or so since the bike kicked out on me and went down a few times..... my knee joints have taken the brunt of the damage.
    doug,im with ya. i think it is a few different things combining for the problems too... time to start customizing!!
  19. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    I have the same problem as lankydoug... Accidental neutrals have cost me a couple of get offs, always seeming to happen at the worst time. I wear a size 12 Alpinestar Tech 3, which has a pretty large toe box. I hate the (lack of) feel these boots provide, so will be getting Sidi Crossfire ATs. Anyone gone from Tech 3 to Crossfire ATs that could comment on how the sizing translates? I'm unsure whether to go with 12.5 or 11.5 since I have a little bit of wiggle room in my Tech 3 12s, but I have heard some mention that Sidi's fit a bit on the small side.
    Regarding the shifter, I raised mine a single spline from how it came when new, and it started hitting the chain when upshifting, so beware of that. Only a couple of shifts had chewed about a mm into the shifter.
    I could use a shifter that's a bit longer and with a higher end. Any recommendations?
  20. HuskyT Moderator
    Corona, California
    If the bike is kicking/sliding out on you it can be a number of things... biggest being probably your tire. Personal choice but having gone through several tires now princiapally riding the track the best track tire hands down for my TC450
    Dunlop 756 rear - sticks like glue everywhere.... wears out quick though
    Bridgestone 403 /404 combo - good intermeditate tire
    Maxxis Desert IT.... never again
    Stock Pirrelli.... lost the bike out from under me all the time....
    Good luck and protect those knees!
    T
