Bike cleaner for dirt bike
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by ks9mm, May 22, 2014.
  1. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    OK....yes, I know its a dirt bike.. and there is sort of charm in having your bike all muddy and all.. but I like my bikes clean :)
    so far I used S100 and Suzuki bike cleaner (it works awesome),
    so what do you guys use to get all that mud of your bike?
  2. BadMotoWeazal Husqvarna
    Alabama
    I like to use a dirt scraper & a strong stream of water to remove excess. I like the Suzuki wash, dilute it half & half with water. Spray motor down & let it simmer, start with the top & scrub everything with a brush. One section at a time hosing off as I go. Come back to the motor & spray again with soap. Brushing everything my little brush can hit. Wheels last thing I wash. I always remove my air filter & use the air box cover. Use the old leaf blower to remove water from all the cracks & crevasses.
    ray_ray and 268fords like this.
  3. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    i was an S100 fan for a while but it gets too expensive...
    50/50 Simple Green/water mix in a spray bottle, good spray nozzle on a regular garden hose (i don't powerwash anymore), spray off the heavy stuff, spray either half or 1/4 of the bike down with the Simple Green/water mix, good paintbrush to 'brush' it all in, let sit for maybe a min or two, never more, blast off with the hose... continue on. always do this to a cool bike out direct sunlight or do smaller sections if in the sun. you don't want the SG mix sitting long or drying on.
    works awesome. paint brush is key.
    ray_ray likes this.
  4. motorpsycho Husqvarna
    Michigan
    2012 WR125
    Kawasaki ZRX1200R, Suzuki GT550
    +1 for Simple Green, however I prefer the purple Simple Green over the normal stuff....
    Do NOT let that stuff sit long or dry tho.
  5. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I don't ride mine. I only put aftermarket stuff on it and look at it while I drink beer.
  6. DTX915 Husqvarna
    wr125
    kdx200 tt500 yz450 klx125
    I put simple green in a big sprayer two gallon's at a time and just pump it up and spray away. Works better than a squirt bottle.
    Motosportz, ray_ray and JAM like this.
  7. ALLTRQ Husqvarna
    Sydney Australia
    2011 TE511
    CT18 is the poison of choice here in Aus. I get the feeling it may be quite similar to your simple green.
  8. Rick Husqvarna
    Lodi, Ca
    99 GasGas EC 200 , 05 YZ 125
    Shout, the same stuff that removes stains from your riding gear. Shout has a neutral pH which will not streak aluminum. works really well on keeping your engine cases looking fresh and clean.........put in a spray bottle and spray away, not need to mix.
  9. columbia510 Husqvarna
    columbia,ca
    Krud Kutter works well, I get it at Lowes for $24/gal. Simple Green is almost as good for a fraction of the cost. I use a electric pressure washer then WD-40 all the critical places afterwords.
  10. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    Will try simple green. I like my bike clean and shiny at the beginning of the ride :)
  11. Mike-AK Husqvarna
    Alaska
    2012 TE 310
  12. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
  13. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    + One for CT18 in Aus!
    THE best bike/car/truck wash around.:thumbsup:
    I bought a cheap Hills mini pump-up sprayer from Big W to apply it.
    When the bike is all clean and dry, I spray it in silicone tyre shine, motor, plastics, up under the guards etc. (Not where you grip the bike with your legs or brakes obviously)
    It helps stop the next lot of dirt sticking & makes washing off a heap easier.
    My bike has 119 hrs on it now, almost all off-road, it's covered in scratches in this pic, but is still clean & shiny.
    Boogie, ks9mm and Schrup like this.
  14. ghte Husqvarna
    Bright, Victoria Australia
    Hey Danger mouse, looks brand new to me mate. Good job.
    Dangermouse449 likes this.
  15. Dangermouse449 Husqvarna
    2011 TE449
    Maybe I should have got a bit closer with the camera :)
    It was upside down on the bars & rear guard 3rd time I rode it....
    Looks new today though.
    Fitted white panels & a new sticker kit :)
    Tinken likes this.
  16. Boogie Husqvarna
    Australia
    Red head
    + 2 for CT18
    Just curious how many km's for 119 hrs?
  17. Dangermouse449 Husqvarna
    2011 TE449
    3400 km.
    Probably 500 on the road total.
    Boogie likes this.
  18. Boogie Husqvarna
    Australia
    Red head
    Thanks. 310 lacks an hour meter so just trying to figure hours for my 3000km
  19. Sceep Husqvarna
    'Burque
    '09 te310
    '94 st1100
    x2 on Shout, the stain lifter. stuff is amazing. we buy it by the 4 gallon case at Costco, and dilute it 75/25 shout/water in a weed sprayer.
  20. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    i use liquid laundry detergent and a scrubbing brush together with the pressure cleaner after the clean up spray with lanotec
    Tinken likes this.
