Bike Stands and Jacks
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by mikebru, Dec 7, 2012.
  1. mikebru Husqvarna
    Ocean County, NJ
    2009 WR250; 2012 TE449; 2005 TE450
    What kind of stands and jacks does everybody use in their garage/shop?
    I have a typical aluminum stand for my TE449. I'd like to get some kind of lifting stand/jack so I don't have to muscle the bike up onto the stand anymore.
    I was looking at the Harbor Freight one for $30. http://www.harborfreight.com/automo...s/350-lb-motocross-dirt-bike-stand-66552.html
    But then I read some of the reviews and it is probably garbage.
    I also looked at this one from them: http://www.harborfreight.com/1500-lb-capacity-atv-motorcycle-lift-2792.html. Doesn't look too bad for $90.
    Thanks,
    Mike
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    I use the harbor freight hydraulic stand, but I modified it to lift taller. Has a handy place to put tools/parts now and lifts the rear tire over a foot off the ground.
    Blakelpd5 likes this.
  3. mikebru Husqvarna
    Ocean County, NJ
    Thanks Tinken, looks good.
    Where did you get those rear turn signals again?
  4. andyman Husqvarna
    I have the $30 Harbor Freight one. I've had it for probably over 2 years now. So long as you put the safety pin in once the bike is up, it's fine. Mine sits on that stand every day. I even ran the stand over in a field with my 3/4 ton diesel truck, and had to dig the stand out of the ground and straighten it with a vice and cheater bar. It does have its limitations, but it's certainly not junk. Just use common sense (use the safety pin) and you'll be fine. Heck, my bike is sitting on that stand in my avatar pic to the left!! :)
  5. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    I use the OGIO hoop style because it allows the bike to cradle between the cross rails instead of rocking on a flat surface. Can easily pull both wheels with no fear of tipover.
    I DO NOT recommend using the clever roll on/roll off feature as it requires quite a bit of space to do and is tricky to execute, may require adding some traction help on front of frame.....
    Tinken likes this.
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    These are what I used for the front:
    http://www.cyclegear.com/eng/product/LED_Arrows_Short/web1006857
    The rears are also led flush mount stick on, but I drilled a 8/32" hole through the center and bolted them on. They came from CycleGear as well.
    You will need a new flash unit if you run all led's like the one I installed here:
    http://www.cafehusky.com/threads/2012-te511-license-plate-solution.25485/#post-253125
    I found a 65 watt headlight too that only draws 35 watts, haven't had a chance to pick one up and test it yet though.
    http://www.cafehusky.com/threads/replacement-bulb-449.29240/
  7. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    FWIW, that stand does not clear the 630 headers when using the roll-on feature.
  8. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    i have an old beat up one similar to the harbor frieght hydraulic unit... my fav two things about it are:
    Not having to muscle the bike onto a stand
    Being able to move the bike around the shop while elevated, with the wheels off..
    Tinken likes this.
  9. Radar Husqvarna
    Southern Nevada
    2012 TE449
    Thumperama and everfree like this.
  10. Fast1 Husqvarna
    Minneapolis, MN
    Harbinger and Tinken like this.
  11. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    They still make the scissor jacks for pretty cheap, how stable is it though?
  12. mikebru Husqvarna
    Ocean County, NJ
    So I "splurged" on the $30 Harbor Freight model. $24 with the coupon.
    It has held the bike up for 2 days so far!
    Tinken likes this.
  13. NephronRacing Husqvarna
    Minneapolis, MN
    2002 CR250
    '98 Ducati 748, '69 Honda CB350 Cafe
    I use a DRC HC2 when the Husky is parked. I use a Harbor Freight Motorcycle Lift Table for working on all the bikes. Much nicer than just a stand when working on a bike. I'd love to upgrade to a Handy Lift but the HF Lift Table works fine at half the cost of a used Handy. I would recommend changing the wheel vise with a Handy or other heavy duty one. I haven't but keep saying I will build or buy one.
    Tinken likes this.
  14. Fast1 Husqvarna
    Minneapolis, MN
    Ive never had any problems as long as I secure the pegs to the base with the hooks.. Really like it for working on the bike and it allows easier access to many locations on the bike without getting yourself so contorted that you can move the next day.
    Tinken likes this.
  15. oregonsage 4st Clerk
    Dry Washington
    FX450
    My brother has a Harbor Freight unit which works, unless you breath too hard on the lever....seems the detent position on his is a bit weak.
  16. NephronRacing Husqvarna
    Minneapolis, MN
    2002 CR250
    Can't say that mine is weak but then again, I always use the bar and lower it. The hydraulics aren't the best so I'd rather let the load rest on steel.
  17. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    I think they are talking about these ones:
  18. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Seems like each type has it's advantage, but the black and red roll around is very versitle for most things except oil changes. I have two of the table lifts that probably get used the most and also can be used as a parking space or rolled under the bench to make more floor space. The lever action lift/stands are great too and can be used on the table lifts for the best of both worlds.
    Thumperama and fasteer like this.
  19. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    ray_ray likes this.
  20. Jack Husqvarna
    San Jose
    Rhino stands work very well too. They are a bit more money than the HF types, but of course you get what you pay for.
    http://www.rhinostand.com/
    everfree likes this.
