All 2st Bike won't start
Discussion in '2 Stroke' started by RusRider, May 13, 2012.
  1. RusRider Husqvarna
    I was love my husky WR250 2011 while weather was less than 50f.
    Now here is 54-59f and it's where the problem starts!!!
    I can fire it up only once a day when it's stone cold when it warm I can't start it no mater what!!!
    it runs strong when it works!
    I've changed main jet, pilot jet, played with air screw... Nope
    So I've spent all weekend in the woods trying to start it.
    Now it has 430 main, 35 pilot and 3 clip at needle. See level area.
    I'm very pissed with this situation, please help me figure out how to solve this problem.
    May be it's not carb issue?
    Thanks!
  2. Lincolnlock Husqvarna
    Mount Vernon, WA
    When the bike won't start, have you checked spark? That would be my next check. It could be something as simple as a bad shut off switch,
  3. RusRider Husqvarna
    The spark plug checked several times. The spark is at place.
  4. windsurf Husqvarna
    queesland
    Sounds like it is still too rich, check float level as well as jetting. Does it start with a push when it's warm? If so almost certainly too rich. When its warm and wont start try a fresh plug if it starts with that its probably too rich.
  5. Lincolnlock Husqvarna
    Mount Vernon, WA
    What happens when you hold the throttle 1/4 of the way open when you are kicking it? That will tell you if the mixture is rich.
  6. RusRider Husqvarna
    Seems to start but only if you find long downhill.
    1/4 throttle? Not sure but looks like at 1/4 was the spot where it was very close to start.
    Also it kicking back sometimes and sneezing out of silencer.
  7. Lincolnlock Husqvarna
    Mount Vernon, WA
    Your pilot is rich. Hold the throttle open a little further, or all the way. It will start. The fix would be to install a smaller pilot.
  8. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    How many turns out on the air/fuel screw? that would tell you if your PJ is too big giving you starting problems.
  9. RusRider Husqvarna
    I've tried from 1,5 to 2,5 turns, without any achievements. For me it's hard to judge when I can't start the bike.
  10. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    What does your plug look like after it runs for a short time?
  11. RusRider Husqvarna
    It was dark brown almost not corbanated.
    Spark become wet while I kick it.
  12. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Probably a combination of float level too high and pilot too rich. A 27.5 or a 30 pilot would probably get you in the neighborhood. I had to adjust my float a very small amount to solve a starting and poor mileage problem.
  13. RusRider Husqvarna
    My bike is also have poor milage, but I was thinking that is ok for 250.
    The smallest jet that I have is 35, so I try to adjust float first.
    Do you know any good articles how to do it?
  14. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Read this first http://www.iwt.com.au/mikunicarb.htm then mark your throttle with tape 1/4, 1/2, 3/4, and adjust one circuit at a time. Be patient and write down your settings so that you can compare. Once you get it perfect write it in the back of your owners manual so you can reference it if you change pipes or gearing or altitude ect. Enjoy.. you will be amazed how well the bike will run when it's crisply tuned from bottom to top.
  15. RusRider Husqvarna
    Thanks!
    Do you have also information about float checking and adjusting?
  16. lankydoug Husqvarna
    MO
    WR
    TM 300en
    The way I set mine is to bend the tab in small increments until fuel does not pee out of the overflow until the bike is leaned at approximately a 45 degree angle to the left. If it pees early it's too high. Every time I am going to cold start the bike I lean it to the left and just before the peg touches the ground it pees. This puts some fuel in the engine for the cold start. I then pull the choke out and one or two kicks and it's going. I know this is not scientific but it works out to be the same as the measurement that others have posted on the jetting chat. If you want to measure make sure you hold the carb upside down at an angle because the weight of the float on the needle spring will throw off the measurement. Basically the float will be slightly below level when the fuel is shut off. (carb right side up)
  17. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    Do a search. Someone made a thread with photos on adjusting floats.
  18. RusRider Husqvarna
  19. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    6mm. The side edge of the float should be parallel to the side edge of the carb body when the valve closes.
  20. RusRider Husqvarna
    here is how my float looks right now. Seems to be too high.
    But i can't figure out what I should adjust and how.
    kindly ask to help me.
