bing float level
Discussion in 'Vintage/Left Kickers' started by crankpin, Sep 28, 2009.
  1. crankpin Husqvarna
    England
    I've done this a million times, but this carb has given me some grief :banghead:
    First, the float pin had seized and was a bugger to remove, next the plunger on top of the float valve was seized. luckily I had a spare.
    The main jet was blocked solid (a 195) and I could only find a 200, so that went in.
    This is where I may need your collective knowledge, the manuals I have for this model are more than a little vague when it comes to float level height, so I set it as per most carbs with this type of float valve, level floats as they rest on the float valve without depressing the plunger (2nd image). Is this correct? :excuseme:
    Next, reassemble the carb with new o rings, and test it off the bike, ensuring a good dribble of fuel left the carb when the tickler was depressed. I then installed the throttle valve and fitted the carb to the bike, and re-test, perfect, you might have noticed that I swapped the carb flange bolt for a socket head.
    All that's left now is a proper running test and plug chops ( I hope)
    Oh, while I'm typing, is there a paint which is fuel resistant?
    I normally use PJ1 fast black with good results, but this time, the paint goes soft on top of the engine where the carb drips after using the float plunger.
