Bing replacement
Discussion in 'Vintage/Left Kickers' started by mtbrider, Sep 10, 2010.
  1. mtbrider Husqvarna
    Australia
    I have a 1974 CR 125 and I am looking to replace with a Mikuni. Has anyone any experience with this in terms of model used and jetting.
    Help appreciated.
  2. Trailridernut Husqvarna
    Texas
    I can't say exactly as I run a 250, but, I run a 38mm - you could probably run a 34 on the 125 on the big end... hopefully somebody will chime in.
  3. firecrackerkid Husqvarna
    Grand Coulee, Washington
    78 390 OR, 84 250WR, 83 175WR
    Many years ago, replaced with a 32 on a 74 wr125.
  4. mtbrider Husqvarna
    Australia
    Thanks anyone know what jetting.
  5. mtbrider Husqvarna
    Australia
    BUMP
    Does anyone know or even want to guess at the Jetting for a Mikuni 32 on a CR 125 1974
  6. Parh 474 Husqvarna
    Newbury Park, CA
    '73 Cr125, '06 Cr125/144
    Ossa, Bultaco, Puch, Maico, AJS, Yam
    1973 Cr125 Mikuni jetting
    I run a 32mm VM Mikuni on my 1973 Cr125.
    Try starting at:
    30 pilot
    Q-0 needle jet
    6F5 needle on the 2nd slot
    2.0 air jet
    2.5 slide
    290 main jet
    Note: I have very modified porting, a custom pipe, .030" piston to head clearance (high compression) and 3mm BTDC timing with a PVL ignition.
    If you're going racing I can supply porting and pipe specs. Got a few holeshots and wins in AHRMA national competition.
    Craig P
    #474
    California
    P.S. If your Bing is not worn out it's a good carb
  7. Parh 474 Husqvarna
    Newbury Park, CA
    If you run a UFO slide insert (highly recommended) use a 15 pilot and a 3.0 slide. http://www.thunderproducts.com/u_f_o.htm
    Craig P
    #474
