Bleeding the front brake (Strada, ABS)
Discussion in 'TR650' started by adara, Feb 24, 2014.
  1. adara Husqvarna
    Sweden
    Kawasaki KLX250
    So, I've been stupid. After years without any incident, I've finally managed to go where so many others have gone before and tried driving off without removing the disc lock first.. :banghead:
    Luckily, not that much was damaged (apart from my ego), but I do have to switch out the front brake caliper as the screws broke off. Not something I've done before and I'm not the most mechanical person ever, apart from the usual maintenance.
    So, any help you guys can give me would be greatly appreciated! That being said:
    Is there anything to keep in mind when bleeding the brakes, given that there is an ABS-pump in there somewhere? Or is it enough to open the nipple in the caliper and let the fluid run out?
  2. glitch_oz Husqvarna
    AUS
    Strada
    Yes, stock-standard bleeding procedure of pump up and hold lever-> open and shut bleeder nipple quickly-> repeat ad nauseum until you have the right pressure and all air out of the system.
    Not a quick job, though... 2-3 times as time-consuming as a non-ABS front bleed due to the long lines to and from the ABS unit.
    Just did it last weekend after emptying the Master cyl to re-position the front brake line which was all crooked ex-factory.
    nev.. and adara like this.
  3. thumperstruck Husqvarna
    Boise, ID
    You both said nipple
    nev.. likes this.
  4. adara Husqvarna
    Sweden
    Kawasaki KLX250
    Great, thanks glitch!
  5. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    ABS brakes usually have a procedure involving the ECU and the can connector/device. I have a hexcode 911 and on the BMW ( which has a similiar ABS) you hold the lever in and run the bleed pump cycle. Hexcode have no upgraded the 911 to be able to see the Husky TR but I haven't tried the bleed procedure yet on it. The husky interface still has a few bugs though.
  6. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    Don't you hate it when the most important letter in the sentence is missing.
    Hexcode have noT upgraded the 911 to be able to see the Husky TR
    Hexcode have noW upgraded the 911 to be able to see the Husky TR
  7. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    My typing is just SOOOOO good. Sorry. The 911 is NOW upgraded so i8t can recognize the TR ecu.
