Buddy had this 2005 610 sm for the summer and rod bearing went out and did some damage..dealer wants 3800$ to fix motor, i cant find a used motor anywhere. Any ideas? part it out? get parts from dealer? needs rod, bearings, piston, crank, and then some... seems hard to find used parts for these things. any help much appreciated! thanks
Call whatever dealer you want, order parts, fix bike. The entire crankshaft assembly (including rod, bearings) is about $550 from Hall's. The piston assembly is about $300. There's also this: http://www.ebay.com/itm/Husqvarna-S...pt=UK_Motorcycle_Parts_13&hash=item1c36eec48a I'll be honest, I'm not exactly sure what you're asking...
We can rebuild it and mod the crank so that doesn't happen again. Call us and get a quote. 760.244.7028
My 630, with about 20.000kms on the clock started a ticking noise coming from the lower reaches and has been diagnosed with a duff con rod bearing. RepairĀ“s going to be expensive.
