Borescope inspection of cylinder
Discussion in 'TR650' started by DeLewis, Jul 23, 2016.
  1. DeLewis Husqvarna
    Melbourne, Australia
    Today I carried out an inspection of the piston with a borescope to gauge the condition of the engine. The results don't look too good to me. The images are not great but there appears to be build up of oil or carbon glazing around the edge of the piston and a strange patch of metallic discolouration.
    The engine has only done around 23,000km. Anyone know how to interpret these results??
    Photo on 23-07-2016 at 2.22 PM.jpg Photo on 23-07-2016 at 2.22 PM.jpg Photo on 23-07-2016 at 2.23 PM.jpg Photo on 23-07-2016 at 2.33 PM.jpg
  2. DeLewis Husqvarna
    This is the Pulstar plug that has been in for around 2000km which is looking a healthy chocolate brown. The previous plugs had some carbon deposits. When I changed over to the Pulstars I also reduced the setting on the AF-XIED to make the fuel mixture leaner as I was concerned about carbon build up in the combustion chamber. image.jpeg
  3. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Your cylinder wall looks a bit shiny. Can you get a better shot of that, maybe higher up near the head?
    I recently did my Strada, and the walls looked perfect. Not glazed, beautiful even cross hatching, no scratches. Minimal deposit on piston. 18k miles on engine, oil changes at 6k mile interval (synth).
    What mods does your bike have? Air filter? Fueler?
  4. WayneC Husqvarna
    Sydney
    F650GS Dakar
    Ditch the AFXIED
    Mark_H likes this.
  5. DeLewis Husqvarna
    Yes I've just removed it today. Hopefully the carbon will burn off in time. A bit of a wake up call though to the risks of running too rich for too long.
  6. DeLewis Husqvarna
    I've been using the AF-XIED for a long while - although I've now removed it - PodMod and I run it with the front airbox door off most of the time. I just took it for a blast down the highway without the AF-XIED and its running very well. Obviously it's too early to say how it will run after the adaptation trims have settled, but I'm hoping the Pulstars resolve the stumbling.
  7. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    What setting were you running it at?
    I'm running the AXFIED currently. It smelled rich when first started using it. Not sure what setting I'm running it at, without looking. I'm sure it's the recommended setting.
    Quite awhile back there something about some units possibly not working. Anyone recall that??
    As little as I ride my bike, I got go back and check to see if it is working.
    This thread is making me think about going back to the PCV (good thing I never sold it).
    It would be nice if I could get Tinken to map my PCV, like he did for another member back sometime ago. Not sure if that was before he left Zip-Ty. Tinken, if your still around, and able/willing to map mine, let me know please. Thanks!
  8. WayneC Husqvarna
    Sydney
    F650GS Dakar
    Neither the AFXIED or PC5 can resolve the firmware problems and neither allow you to see with diagnostics what the O2 readings actually are
  9. DeLewis Husqvarna
    Mostly I had the AFXIED set around 8 which is within the recommended range. One of the reasons I decided to check the cylinder was that I had found carbon build up on the previous plugs and the exhaust gasses smelled too rich. I'd definitely recommend checking inside the cylinder and consider removing any fuelling device if the bike will rum satisfactorily without.
  10. PaulC F class
    Bayside Brisbane, Australia
    TR Terra
    Apart from the colour, it looks normal to me. If it runs and behaves better/safer I would continue using the Afxied.
    14.7 AFR is ideal for emissions standards but IMHO not for motor longevity and rider safety. At least where the TR is concerned.
  11. DeLewis Husqvarna
    I've done around 120km since removing the AFXIED yesterday and the results have been positive so far. The engine is running at least as strong and while it occasionally stumbles and stalls on deceleration, it is no different to the AFXIED set to 6. It never ran this well without the AFXIED prior to installing the Pulstar plugs. Therefore, it is my tentative conclusion that the Pulstars have mostly rectified the dangerous stalling/stumbling. I think there is a place for devices such as the AFXIED and it certainly improved the running early on. I'm just a bit paranoid about the perils of carbon build up for engine health and longevity.
    PaulC likes this.
  12. PaulC F class
    TR Terra
    Nice, My bike didnt stall in winter only in summer. At least removing the afxied will give your cats a chance to burn off the extra carbon if you have still got em. Hopefully the potential aussie recall will fix that. Although its still far from perfect.
    DeLewis likes this.
