Brake Fluid Brake Pads
Discussion in 'General (Main)' started by robertaccio, Dec 9, 2010.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    I cooked my rear into 0 rear brake coming off some of the hills which generally wore me out compensating with too much front and with clutch/gear braking.
    I have been using Maxima 550, my pads are new and are EBC reds my disc is the oem solid rotor. Let me hear what you hard rear braking enduro guys are using. I have a reservior extender all ready on the machine. I am thinking because we are not very wet or muddy here a more open (wave rear rotor) disc as well.
  2. ajaxauto Husqvarna
    Robert on my Wr 250 i would over heat the brakes But then i changed to a vented rotor from a CR 250 and motoul brake fluid also better pads from Halls no problems now
  3. robertaccio Husqvarna
    San Diego, Ca
    Thanks John I am working on getting an open rotor/disc vice the solid OEM one, which is probably a little worn after 2 years . We are rarely in mud/wet here anyway.
    The Motul 600 you said has also been recommended by a bunch of others as well. Honestly I think my main issue was settling for standard EBC pads that were in stock. So with the Motul 600 and fully sintered race pads, as well as a wave/vented etc disc I think my issue will end. (this was the first time for this issue)
  4. robertaccio Husqvarna
    San Diego, Ca
    step 1 will incorp use of Motul RBF 660.
    2 will install fully sintered racing pads CM46 type Braking or equivalent SBS or other (my mistake for using the lesser/cheaper pads in this round of maintenance.)
    3 Will price later model wave type floating rear disc/rotor.
  5. ARod2000 Husqvarna
    Georgia
    Agreed :thumbsup: I don't think you need to change rotors to notice a big difference, just pads.
  6. robertaccio Husqvarna
    San Diego, Ca
    Found the EBC high end ones to be equal to all the other top brands racing pads in full sintered metal racing specification so I have those on order because they are readily available from PU. I have a bottle of Motul RBF660 waiting in my "inbox" at the shop as well.
    I have an in at Braking and may be able to get a rear later model disc (the Husky 2010 models are wave type with perforations) that will wait for now. I just replaced my front disc.
    MXS368 R and MXS181 F
