Brake hose wear
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by ADSTE, Jun 28, 2014.
  1. ADSTE Husqvarna
    Fern tree gully
    Te450 2010
    Please see and advise......I can see the bracing is starting to wear through..can I maybe sleeve the bend of hose with a conduit or small tube over it for protection?
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Loosen the banjo bolt slightly, rotate the hose so it doesn't touch the case, and re-tighten the banjo bolt.
    This seems to be a Husky standard feature. Italians...
  3. rancher1 Husqvarna
    WA
    It can also wear to the case so do as Kyle mentions above, it is also free and easy !
  4. ADSTE Husqvarna
    Fern tree gully
    Te450 2010
    And protection ideas
    Cheers guys
  5. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    zip tie a bit of old HD tube around the area-problem solved
    ADSTE likes this.
  6. ADSTE Husqvarna
    Fern tree gully
    Te450 2010
    Good idea
    But don't have 1
    I have some split plastic conduit that I'll try ..see how it looks and post up.
    I'll look for some rubber at work too
    Cheers
    shawbagga likes this.
  7. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    Also keep an eye on the line up from the master as the chain slap will eventually eat it.
  8. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    i just used zipties to pull the loop back in addition to loosening up the master cylinder banjo and adjusting the loop position. just need to play with the loop. been the same since my 06 te450,txc450,te310,txc310r.they all rubbed the engine block while the swingarm moved
    ..not the best setup just one of those red husky quirks,
    waserman likes this.
  9. waserman Husqvarna
    Delaware,USA
    09 TE510
    BMW KTM Honda
    I think you may be refering to the 2 strokes the chain is on the opposite side on ADSTE 2010 TE450, but good info for the 2 stroke guys .
    robertaccio likes this.
  10. robertaccio Husqvarna
    San Diego, Ca
    additional I also used split convoluted tubing on my TXC450 with zip ties over it for more chafe resistance, the kind you can buy in the auto parts store (but mine was a mil-spec type). I will try to find some fotos.
  11. robertaccio Husqvarna
    San Diego, Ca
    2008 TXC450 set up
    ADSTE likes this.
  12. ADSTE Husqvarna
    Fern tree gully
    Te450 2010
    That's what I plan to try......I have some of that exact hose.
    Cheers Robert
  13. AlwynMike Husqvarna
    TE310R
    Honda CRF 250x, Suzuki GS1000
    After having a look at mine in preparation for tomorrow's ride, I am very disappointed.
    Mine does not seem to have this feature as standard, and there seems no way to modify it to wear through, even with the rear wheel as far forward as possible.
    Should I take the bike back and ask for a refund??
    Maybe it's an "extra" that you guys get in the 'States as a little Italian bonus - and the Italians have been short-changing us Brits (let's not get into politics!)
    :lol::lol::lol:
    Mike
    Kyle Tarry and duggoey like this.
  14. ADSTE Husqvarna
    Fern tree gully
    Te450 2010
    Sorry to hear you didn't get this feature.........you could always ask for a retrofit
    Cheers. Enjoy your ride
  15. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    We got it as part of the deal over here so it might be so. In fact they were so thorough that it nearly rubbed through my case.
  16. ADSTE Husqvarna
    Fern tree gully
    Te450 2010
    We'll hose is fitted. Used from an auto shop here in OZ. image.jpg and some motul 7100 and a filter to finish the service.
