Broke the brake pedal tip on my TE - pedal is fine but I need just the tip. Does anybody do a spring-loaded tip that I can fit ?
I installed a KTM tip from one of my old KTM pedals...(temp fix) also the OEM tips shear fairly easy I lost 1 on my 04 and 2 on my 06, . After I ordered a new OEM pedal, I had the inside of steel pedal piece welded to strengthen the end of the triangle. The OEM pieces are only lightly welded on the outside, after welding up the inside I never had issues with it shearing off, ( none were sheared from crashes, just from scraping against rocks).
Motoxotica sells Husaberg (TM?-cant remember) tips that bolt on. Nice up grade. Sheered my '05's brake a couple times.
