dfeckel
2008 CR 125
So at my last enduro, which was a sloppy mudfest, I started to have some front brake issues. My lever, which has been feeling a bit spongy the last few races, progressively pumped up to a super-hard lever pull, which culminated in a dragging/locked front wheel. The pads were very worn, maybe 1mm from the backing plate. I had been stuck badly in a couple mud ruts, so I figured that I just packed enough mud into the caliper that the sliding pins weren't sliding any more and that was why it wasn't releasing. I cleaned up the caliper in a puddle at a reset and went into the final section, where the front brake locked up in the exact same fashion. So I pried the pads apart and finished the race with just the rear brake.
I immediately cleaned everything up and put in new pads. I checked the fluid level, which was okay, but the lever feel was still spongy. Today I flushed and bled the system, but it's not behaving right. First, when I was trying to build up pressure in the line to bleed at the caliper, I would have to pump the lever 20-30 times to get ANY pressure, and what pressure I got was very slight. There didn't appear to be any air coming out at the bleeder after several rounds of this. In fact, I probably flushed four resevoirs full of DOT 4 through the system in this fashion, and the lever just wasn't coming up to good feel. I finally got a little bit of pressure at the lever, put the resevoir cap on, bled one or two more times and tried it out. Lots of mush at the lever, but some braking action. If I pull the lever just about to the bar, I can get some lockup on pavement.
What's going on here? Any ideas? I bled the back brakes with no problem--easy pressure buildup at the pedal during the bleeding process, so I don't think my bleeding technique is suspect. I just want that two-finger stoppie front brake I used to have!
