125-200cc Bringing back the WR
Discussion in '2 Stroke' started by robj, Jun 16, 2013.
  1. robj Husqvarna
    NZ
    2001 CR125
    KX/KDX200 hybrid
    Thought I'd give you an update on the WR refurb.
    I bought it a while back off a guy who butchered it through neglect and idiot mechanical skills. Frame tabs were snapped, bolts threaded, bearings seized solid, forks dented - the list is too long. He even managed to crack the swing arm at the pivot end. Only one word to describe this guy's approach to maintenance - dangerous.
    I took it back to the frame - blasted and powder coated it, repaired all damage and replaced worn parts (including swing arm). I've also hooked up a set of 49mm twin chamber Showa conventionals (retaining the original WR wheel). New seals, rubber, guards, suspension service etc.
    It's on the home run now after reassembling the big bits. Now just detail stuff - mounting headlight, hand guards, new Fatty, repacking muffler. Hope to have it finished in a week.
    I'll keep you posted!
    DaveG321, rockdancer and sabortooth like this.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    that a wr 125? looks quite modern what 07?
    like it looking tidy, so many people dont know how to check oil let alone greese bearings and bolt torque settings.
  3. robj Husqvarna
    NZ
    2001 CR125
    KX/KDX200 hybrid
    It's a 2010. Hard to think it could get that scruffy.
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    hell i thought that was too bad a condition to be 3 years old! man stay away from thet bloke in the future thats nuts..
  5. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Nice work - you are doing it the proper way
    Forks sound interesting .
  6. K.Forte' Husqvarna
    Any great singletrack trail..
    2010 WR 125R
    2004 Honda CRF 302X
    You might want to also beef up the coil mount tabs,mine broke off i used some flat steel 1/4x1/8 and welded them to existing tabs(reweld'd broke one) and then weld'd straight to the frame,,also the front engine mounts cracked at the welds,fixed that problem too.. Nice looking rebuild!!!
  7. robj Husqvarna
    NZ
    2001 CR125
    KX/KDX200 hybrid
    The coil tab had broken on mine too. I like the sound of the mod you did - maybe next time round if my weld doesn't hold out. All engine mounts looked ok.
  8. wallybean Mini-Sponsor
    Montana
    Nice work!
  9. K.Forte' Husqvarna
    2010 WR 125R
    2004 Honda CRF 302X
    Thanks,,ya its pretty stout now,,i put 2 extra welds in front of the factory ones for the front engine mounts..
