250-500cc Broke top triple... why?
Discussion in '2 Stroke' started by Leepet, Apr 6, 2013.
  1. Leepet Husqvarna
    Hi, i was reinstalling the forks on the 360 tonight and snapped the top triple clamp as I was tightening the bolts with a torque wrench.
    I'm a bit surprised by this. I would have thought that the first thing to go would be the threads in the alloy. Has anyone got any idea why this would happen? There appears to be two colours in the broken area. Could I been riding with a cracked clamp for a while?
    Also, can anyone tell me what triple clamps I can replace it with (2000 model wr360)? I assume that anything from a 250 or 360 from 2000 to 2004 would be ok but there may be other years I can use or other issues like different offset etc. to consider
    Cheers
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    yep that's been broke for awhile aftermarket? BRP yep just checked the website if your right about up to 04 your good . zoke forks? rite?
  3. HuskyTaylor Husqvarna
    N.Harford co. Md
    09 TE310 12 WR 125
    01 FLHR 77 Triumph
    Yup,better to break on the stand than in the air!
  4. Leepet Husqvarna
    Yep. Shiver 45s. Stock triples I think.
    I'm not sure what's more of a worry, either I'm so ham fisted I shouldn't be left alone with tools or I've been riding a bike that was about to kill me.
    Thanks guys
  5. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Probably had a hairline crack already through it...luck it's on the stand rather than out on the track.
    You can just get the top triple tree (or the whole unit) from a 00-04/5 WR or TE Husky.
  6. AUSKY Husqvarna
    Cairns, FNQ,Australia
    08 TE510 96 WR125 00 WR360 13 WR165
    1999 XR250 83 YZ 490
    I agree.Pretty lucky for that to not happen on the trail.
    The darker area is the oxide layer that has formed after the original crack occured & the freshly exposed raw alloy is the shiny section where it continued until it failed when you tightened it up. Have you had a good crash recently?
    I'm sure I've got one at home you can have Leepet.
  7. Jersey Woods I live to ride !
    Monmouth County NJ
    2011 WR 150 2018 TE 150
    KTM EXC 250 F Honda 300 ATV
    I'd be happy it happened on the stand instead of in the woods..... Sometimes bad luck in the garage is a good thing....:D
  8. Leepet Husqvarna
    I havent had any mega crashes lately so im a bit puzzled but I have to be happy that I wasn't at speed when it failed. Still, it's a real pain. I just want to ride on my new suspension!
    Ausky, if its not too much trouble, I'll take you up on your generous offer. I'll pm you to work something out.
    Does anyone know what the differences year to year in the 99 to 05 range? 99 and 00 are the same part number but 01 & 02 are different and cr & wr have different part numbers. I know that the 02 360 had changed geometry but don't know if it was just rake or rake and offset. Just curious really.
    Cheers
    Pete
    ohmygewd likes this.
  9. shonky13 Husqvarna
    Yeppoon, Queensland, Australia
    2000 WR360
    Got the same problem with my 2000 wr360 - can't find an aftermarket supplier though. Have you had any luck Leepet?
  10. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    damn. yer in Oz. i have a man that welds tripple clamps, not much help i know. does a bang on job too. ive no clue what the post is to me but...id be happy to see if it can be welded if you can ship it to SoCal, if no one else local can do it.
    FBF made some wicked nice CNC top clamps for a spell. need to machine a small spacer for the 2000 steerer as its wasnt a very tight fit (same guy here did that too).
  11. Leepet Husqvarna
    Shonky,
    I'm trying to work something out with Ausky so I think I'm sorted BUT the 99 & 00, WR125, WR250 & WR360 triple clamps are same part number so picking up any one of these would be a safe bet. I seem to remember reading somewhere that the only difference between the CR and the WR was the bar mounts but don't quote me on that. The part numbers are different but, for example, the 00 WR triple part number is 8000 69319 and the CR part number is 8C00 69319.
    Ausky reckons the offset is the same from 99 to 04(only change to steering is rake apparently) so I reckon you wouldnt have too much trouble picking up something from eBay that would fit. I know that there is a difference between 00 and 02 with the handlebar clamp setup so that may explain the part number difference.
    Another option if you're feeling brave would be to grab a BRP triple for 01 to 08 and hope it fits.
    pvduke, thanks but I don't know if I can wait for shipping each way etc. I have a weekend ride planned next month so I need to sort this out quickish. Also, I don't know if I'm brave enough to trust a weld in a peace of cast aluminum. I'm sure it'd be fine but...
    Anyway, please forgive my rambling. What's pretty much where I'm at and what I know on the subject.
    Cheers
    Pete
  12. shonky13 Husqvarna
    2000 WR360
    Cheers Pete - thanks for the info. A BRP type option is what I'm after but it looks like I'll have to settle for OEM. I'm still waiting on emig racing to get back to me - but brp, fbf & xtrig have told me they don't make them. I suppose I could try an '01 clamp ........ if they were willing to take it back if it didn't fit that is ......... anyway - I'm in no hurry (yet) - I've got a pw50 in a thousand pieces in my garage at the moment that has higher priority apparently. I'll keep looking for options.
    I'd like to give pvduke's man a go at welding them as well. I don't know much about welding - but I do know there's some talented dudes out there that have a knack for fixing the unfixable ..................... i'm not one of them unfortunately! But a spare top triple would be handy esp if they're prone to breaking ........
    Check out my photo - i think it's torn pretty much where yours did.......
  13. Leepet Husqvarna
    Yep, that's it. I am amazed. Failures like these just shouldn't happen. I know a triple is pretty thin around there but it's steering. The consequences of failure are certain and severe.
  14. Coffee CH Owner
    So... are the 2000 WR360's prone to this?
    I've seen this type of thing before, but not on Husqvarna's...
  15. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    as I recall it is the same as a 99 are they aslo in question, sure would hate a surprize at my age :oldman:
  16. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    Most likley from previous trama or previous overtightening.It is amazing as many crashes twisted front ends etc they dont break more often.You would amazed how many bikes have bent top tubes when check them during seal replacement.All that stress goes somewhere.We have had a few come from the factory in the crate overtightened and broken new back in the 99 -02 era.
  17. 2premo Husqvarna
    Northern NV
    I understand the stress part but the overtighten from the factor part
    funny but making a bike light does come at a price!
    still this is a really big price if they are that fragile
  18. BILLF CH Sponsor
    I probably have a good used one pm me and ill look and give $$.
  19. Coffee CH Owner
    Interesting!
