So the pig went down and when the dust settled, my left hand mirror had parted ways with the clutch lever/mirror perch. It snapped off but is only the front part (the clamping part) that was damaged. Does anyone know if I'll be able to find one of these? My dealer is so useless I'd rather ride with no mirror over dealing with them. JB weld will work for a bit, but I'd like to fix it. I'm not opposed to replacing the clutch lever if that's what it's gonna take
Or see any other bike dealer/ wrecker etc. for one of those, as they are pretty much all the same on nearly all bikes (except Yamaha, which uses left-hand mirror threads on the clutch perch), only the distance between the holes varies. The holes usually are 1/4" - 6mm Also check for mirror threads, which are usually either 8 or 10mm. If one of a Honda road-bike/ Polaris Quad/Buell/Suzuki/ Aprilia etc etc doesn't fit, it could well be one of a Taiwanese scooter. Take the old one along as a sample. 5 bux should see you sorted.
