All 2st broken zerk fitting
Discussion in '2 Stroke' started by marcmo0, Nov 28, 2016.
  1. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    I broke the zerk fitting off the bottom of my linkage. How do I repair that? Are they threaded in or pressed in from the factory? If threaded, do you just use an ez-out like a broken off screw?
    Thanks!
  2. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    should be able too just tap a small flat blade screw driver in the remainind hole and undo it if you dont have a easy out as the are only threaded in about 1/4"
  3. rancher1 Husqvarna
    WA
    I believe the zerk is a 6x1.0 metric thread, I buy them at my local ace hardware.
  4. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    You guys rock! I'll let you know how it goes after work tomorrow. :cheers:
  5. Travis616 Husqvarna
    Ontario, Canada
    2021 TC125
    2006 Honda CR125/134 build
    A small torx bit or a Robertson screwdriver works well if you tap them in to unscrew it also
    NCSteve likes this.
