250-500cc BRP Chain Guide on older WR250
Discussion in '2 Stroke' started by Kevin Sorce, Jun 5, 2015.
  1. Kevin Sorce Husqvarna
    Stockholm, NJ
    2015 TE300
    2009 Yamaha YZ250, Aprilia RST1000
    In case anyone ever wondered about the fitment of the BRP chain guide on an older WR, here it is. BRP does not list that this guide will work on a 1999. Everything looked close enough so I ordered one. Mounting holes lined up perfectly. In my case I'm running a pretty large rear sprocket (don't recall if its a 52 or 54 tooth) so i trimmed about 1/4 inch from the center bottom rear of the chain guide with a dremel just to have a bit more clearance. You don't see this cosmetically either when it is mounted.
    It works perfectly, less drag than the stock guide, better protection from rock damage, and I know it will be very durable based on how difficult it was to cut with the Dremel!
    Petar, lankydoug and justintendo like this.
  2. Motosportz CH Sponsor
    I run those, great part.
    flyingbob likes this.
  3. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    I'm interested! So we simply select the BRP guide for a later Husky? Have you a part number?
  4. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
  5. Kevin Sorce Husqvarna
    Stockholm, NJ
    2015 TE300
    The BRP part # is CGD-9221-B (B is for black I believe since it comes in red also). The earliest year BRP lists is 2004. If it weren't for my larger rear sprocket I probably wouldn't have had to trim a little from the rear center section.
  6. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
