Burned ECU (from shorting it out) Revived
Discussion in 'TR650' started by drzcharlie, Jan 25, 2016.
  1. drzcharlie Husqvarna
  2. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    So is that a fuseable link on the pin outs??
  3. gullywasher Husqvarna
    Monument, Colorado USA
    Yamaha FZ6, Beta 300RR
    Good find by our Italian friend there. I'm Glad you posted it here as I rarely look on advrider due to the volume of posts and threads (and BS) that move through there.
    I owned another bike that was infamous for the ECU crapping out due to contact with the seat pan which would stress the ECU connectors (which in turn cracked the solder joints on the board) as the pan sagged under the riders' weight. Easily fixed by opening the ECU and resoldering those joints, but many people shelled out for new ECUs before that was figured out.
  4. drzcharlie Husqvarna
    No, I don't think so. If you look at the photo (which isn't clear) and read what he said, I interpret it to mean the connector pin melted and shorted against the adjacent pin. What he did was clear the melted part and put silicone in between to keep the pins apart. I think.......
  5. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    It's a tight spot and a low res pic, but it just looks like the loop on a blade fuse.
    It is a great plus, but I still want a working map for my ECU.
  6. WayneC Husqvarna
    Sydney
    F650GS Dakar
    Yes what has been posted is what I suspected from the the first failure from a momentary short, I could not get my hands on the BMS-E to confirm it. I looked at another here in Oz recently and saw the same loss of earth. I would suggest an external earth strap under one of the bolts holding the BMS-E together to guard against problems
  7. drzcharlie Husqvarna
    Don't we all. The Aussies seem to have a leg up. We are still struggling to get noticed here. This sucks.
  8. Baddrapp Husqvarna
    Yucca Valley
    TR650
    It sounds like he soldered in a new link. Resealed the ecu lid with silicone. So far the larger injector, brisk plugs, and PCV has cured my bike. No stalls and runs great.
  9. drzcharlie Husqvarna
    Which injector did you put in Baddrapp?
  10. WayneC Husqvarna
    Sydney
    F650GS Dakar
    I have PM's with the Italian owner who posted the pic's over at Advrider and he may open up the ECU to get some further info and better pic's for us
    In the mean time since the problem also affects the G650GS/Sertao owners with the BMS-E I have put together a pdf with the basics and some of the IC info on my web site on the Repairs/Electronic Repairs page, see the BMS-E Info pdf and the IC data zip files
    After I had looked at a failed unit here in Sydney and well prior to the pic's being posted Engineerk9 fitted an external earth strap from his BMS-E case to earth to prevent it from happening and as per his post in another thread yesterday he has put enough kms on it with the earth strap fitted to confirm it does not cause any other problems, I will leave it to him to show how he did it
    Scott Jones and DeLewis like this.
  11. BLZ2DWL Husqvarna
    Virginia
    That's a great find! Is there anything that should be done to protect the computer from shorting out? Anything others should know to prevent this?
  12. drzcharlie Husqvarna
    I was thinking that I would pull the ECU and coat it with bed liner or plastidip (if they are non-conductive). Most accidents have involved working under the seat and a tool laid on top of the ECU an inadvertently being pushed against the frame and thus ground. Poof.
  13. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Might have a problem with heat management. I would try a heavy weight plastic baggie first.
  14. BLZ2DWL Husqvarna
    Virginia
    I don't understand the issue. You're telling me that the exposed metal body of the ECU is not already a ground? The exposed metal body is (+)? This is hard to believe.
  15. drzcharlie Husqvarna
    If you don't believe it, lay a screwdriver across the top and touch the frame.
  16. drzcharlie Husqvarna
    That's a fair point. I have been using a plastic food storage container upside down on it since this problem first surfaced a year or so ago. It fits loosely so it gets air circulation.
  17. Nick780 Husqvarna
    83 Suzuki GS400E
    The exposed, conductive metal body of the ECU is NOT grounded.
    Be careful. First thing I do after popping the seat off is lay a shop towel over the ECU. Even with the battery disconnected I can't be certain that there isn't something with a capacitance waiting to go off and I'm not interested in finding out... There's been a handful of fried ECU reports from gapping to the frame via an accidental contact with a wrench or similar. Months and $$$ to get a new one paired to your dash/key set.
  18. WayneC Husqvarna
    Sydney
    F650GS Dakar
    The case of the BMSE is connected to earth, that is normal on all ECU's to protect from EMI
    This fault could occur to any of the modern ECU's using the same sockets including Bosch and other brands, a momentary +12v on the case is overloading the current capacity of the earth pin in the socket and blowing away the connection at the back of the socket to the circuit board. The earlier ECU's used larger current capacity pins for power and earth.
    Do not coat the ECU, it will reduce cooling to the ECU and a momentary +12v will blow away the coating instantly. EngineerK9 was already trialling an external earth strap to the ECU case well before the pic's of the internals of the ECU appeared at Advrider and the external earth strap is a result of testing done on a faulty BMSE done here in Sydney
    BLZ2DWL likes this.
  19. BLZ2DWL Husqvarna
    Virginia
    Thanks, Wayne. That makes so much more sense. To think that any manufacturer would mount the ECU 1/4" away from the frame, when contact would fry it, was hard to believe. Avoiding contact with +12v makes complete sense.
    Would installation of a ground strap to the ECU case avoid the frying of the earth pin in the harness if +12v contact is made? Is there a better solution to prevent potential issues?
  20. LED Husqvarna
    Perth, WA
    TR 650 Terra
    I've cutout the plastic corner of a milk container and screwed it onto the +ve battery terminal using a nylon screw to protect against this problem. Can't remember who first suggested this, may have been glitch_oz.
