Busted ecu connector
Discussion in '4 Stroke' started by tempus fugit, Jan 27, 2010.
  1. tempus fugit Husqvarna
    Vancouver, Wa
    Took my suspension out and gave it to ProMotion for upgrades.
    Now it's time to clean, clean, clean. But.....what's this? @$%! The gorilla that worked on this bike last broke the ecu connector. See the side of it broken off? It had a little piece of black tape over it. Also, one pin is bent into the next one, shorting it out. See the black mark in the socket in the mating part where the pin was forced into the same hole with the other one? The bike ran great and gave no sign of any problems. I gently bent it back without breaking it. Anyone know what that pin is for?
    As far as the busted connector, I think I can fix it but also considering replacing. Nothing on ebay currently. Anyone got a line on a used 08 TE450 ecu? Are they plug and play or would it have to be setup be a dealer?
  2. Coffee CH Owner
    Personally I would not worry about it, having worked in electronics field. Seriously.
    On the other hand based on the awesomely clean garage you have, it may bother you. Nice map :thumbsup:
  3. tempus fugit Husqvarna
    Vancouver, Wa
    Thanks for the compliment on my garage.
    I'm just worried about the ecu getting wet and leaving me stranded or ruining it. It's not a sealed connector anymore. I could wrap the hell out of it with duct tape, but that's cheesy. And with all the heat up there it would make a mess. I would feel sorry for the next guy that has to take it apart. Wait, that's me.
    How many occassions are there to take that connector apart anyway?
  4. Pete Husqvarna
    Victoria, Australia
    2014 TE300
    OK i am actually concerned about the cleanliness of your garage. You dont have garbage bags of hair and toe nail clippings in your closet do you? :p
  5. tempus fugit Husqvarna
    Vancouver, Wa
    ha! We made a deal long ago. The garage is MINE. The closets and the rest of the house aren't mine. They're hers. She gets to do whatever she wants in there. I say nothing. The garage is for motorcycles and motorcycle related products, tools, and equipment. And cars and trucks, on occasion. Even the bicycles and lawn equipment are banished to the shed.
  6. Coffee CH Owner
    I honestly see no reason to take the connector off the ecu, ever, unless you are changing it to see if that is why your bike is not working. I've never had my connector off my 2006 bike. Everything can be done via the other connector that goes to the ibeat.
    I would use electrical tape if I was concerned with it, and you may be, you have Vancouver WA as your location. Some electrical tape is self - amalgamation tape that (mainly) only sticks to itself. It does not even need to be electrical tape.
    Home depot, West Marine, electrical supply houses.
    As long as the electrical contacts are made, that is the important thing. Bikes (and riders) will always be susceptible to breaking down for numerous reasons and you should always have back up plans anyway. If you were doing the Dakar that would be different.
  7. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I'd put some dielectric grease and a few wraps of super 88 electrical tape on it and go.
    But, I'd keep looking for a replacement ECU to snag some day. Probable one of the hop up kits that come with a new ECU.:thumbsup:
  8. tempus fugit Husqvarna
    Vancouver, Wa
    Good info guys. Thanks. I thought about using the dialectric grease. I use on most of the connectors. Should I be concerned at all about it getting into the ecu?
  9. Coffee CH Owner
    No dialectric grease will not harm anything. I would not worry about putting that on but after seeing some pics of the water crossings some of you people do......... :eek:
  10. tempus fugit Husqvarna
    Vancouver, Wa
    Good. I will use that then. And some good electrical tape. Thanks guys.
  11. ghte Husqvarna
    Bright, Victoria Australia
    What about shrink wrap or would that require to much heat? The self moulding tape works well. I use it for offshore yacht racing mainly as a shroud cover to protect sails but it melds into itself and seals beatifully. It can be easily cut away later with a sharp knife.
    Ditto on your work shop, I only got the shed.
  12. seymore Husqvarna
    Boise, ID
    That pin isn't connected to anything.
    I would coat the face of the female connector with dielectric and then wrap over the connector to the ECU body with electrical tape. This should keep moisture and dust from getting in.
  13. tempus fugit Husqvarna
    Vancouver, Wa
    Ah, OK good. Thanks guys.
