Butterfly removal instructions te449 2012
Discussion in 'EFI/carb' started by Hernan garza, May 13, 2014.
  1. Hernan garza Husqvarna
    Te445
    Crf230
    Hi, i just bought a te 449 and i see in the forums the 2nd butterfly removal, are there any instructions on how to perform this mod? I cant find it any where
    Thanks
  2. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
  3. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    It's real simple. Just pull your side plastics. I also removed all my airbox bolts for some give (with the valve cover on, you can't get the airbox out of the frame, but removing the bolts helps). Loosen the hose clamp that connects to rubber boot to the throttle body. Then pull the rubber boot out of the airbox.
    There are two phillips screws holding the thing on. I closed the butterfly valve manually and stuck my magnet wand in there to catch the screws if I dropped them. Then remove the screws and the valve plate. Put everything back in reverse order. And grease the rubber boot where it pops into the air box.
  4. Motosportz CH Sponsor
    Keep in mind this "mod" was a last resort for one member here to try and get his bike to run right. This was done with several other mods. It is not a universal take it out and your bike runs awesome mod. It could in fact make your bike run slightly leaner and make it worse depending on how your bike currently runs. Just want to make that clear. Several have done it with good results, some have not had great results, some saw no difference. Also if your bike is under warranty this will most likely void that. Just making sure you have the whole picture before removing it. You are modifying a stock design so could open a can of worms.
    Dangermouse449 likes this.
  5. Hernan garza Husqvarna
    Te445
    Crf230
    Thanks very much! Mi bike its running preety good at the moment, so probably i'm not going to perform this mod, also, i know that there is a race map 3 for my 2012, is this true? Can the dealership normaly can flash the ecu?
    Sorry but i'm new to huskys and here in mexico there is not that much support.
    Thanks for your help
  6. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    easy to reflash. takes only minutes.
  7. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Most dealers can reflash the ecu. The BMW Map #3 is known to the dealers as the "Full Titanium Acrapovic Race Map".
  8. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    I agree with Motosportz above.
    If it is running well, leave it alone. You are one of the VERY lucky ones :thumbsup:
    Most of us have had flameouts/stalling, hanging throttles etc. Enjoy a great bike.
