125-200cc Buying a 14' cr165!!
Discussion in '2 Stroke' started by Chums, Nov 17, 2013.
  1. Chums Husqvarna
    I'd like to discontinue my account
    Well after asking tons of questions and talking to a bunch of very helpful C.H. members I decided to go ahead and get the 14' cr165 to add to my 14' WR300.
    I believe I'm going to do a high-ish comp head maybe something I can do a 50/50 mix with, I was a 230-ish lb faster B rider last year and will likely use the extra power, but none the less need to get on a diet.
    As for extras I'm getting a IMS tank since it's a CR, a lectron whatever motosportz recommends, a rekluse exp 2.0, and I'm waiting on a price for an 18" rear setup, I usually run tgt sub tank bars on everything and am getting the suspension done.
    I've been thinking this could be used as a secondary race bike for real tight enduros and hare scrambles with the 300 being my main bike for the wider open stuff. I guess I'll know what all the hoopla is about once I ride it! Thanks for the help and I'll post a comparison when I can
  2. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Hope you like it . Good choice on the CR vs WR. Which pipe? As you may have read the ktm 200 HGS pipe gives it a bit more top end and 200 fatty more mid .
    If you are tallish Id recommend decent bar risers first up .
  3. Chums Husqvarna
    I believe the FMF fatty pipe and I run Scotts undermount setup so its good for a little higher bar. I'm currently working on a diet plan to drop 30 lbs lol...
  4. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    how big are the IMS tanks(litres please!) if you don't mind me asking?
  5. Chums Husqvarna
    I was told 2 stroke IMS tanks were 2.9 Gal or 10.9777 liters and the 4 stroke was closer to 2.8 gal or 10.5992 liters due to the fuel pump
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    cool thanks, not really worth doing as the WR is 9.5L+ already. clear looks cool though!:thumbsup:
